Question about Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System
Unable to record greeting
How do I record a greeting
  • kakima Apr 17, 2014
    What model Panasonic DECT 6.0 answering machine?
I am unable to record a greeting
read very well your user manual how to proceed in record greeting.
Normally you go to the MENU, and select Record for greeting.
God bless you
Oct 09, 2012 | Uniden DECT 6.0 Cordless Phone ID
I AM UNABLE TO RECORD A PERSONAL MESSAGE ON MY DECT 1580. THE INSTRUCTIONS ON PAGE 11 STATES "1. SELECT COMMAND 8:RECNEWGREETINGS (RECORD NEW GREETING." WHERE IS" COMMAND 8? OR HOW DO I...
On your handset, press the Mute (the button also has an envelope to indicate messages). Press 5 on the handset to stop the playback of messages (if any are on the machine). When the handset beeps, press 8 on the keypad of the handset. When you hear "Record greeting", then speak your message. When you are done, press 8 or 5 to stop recording.
Note the answering machine must be on before you start. Press the On/Off button on the base.
I hope this helps.
Jun 16, 2011 | Uniden Cell Phones
I lost manual. I need to know change message when will be out of town answering message.
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a
call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own
personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the
messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the
system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the
announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded
greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Dec 03, 2010 | Uniden DECT 6.0 Cordless Phone ID
It tells me that I cannot re record greeting - it says unable to fix now
what this simply is that your panasonic phone has been over power by power supply what you are to do first of all put off the phone for some time then put it on again after it most has relax it self then apply the below instruction to reprogram the greeting message on your panasonic phone again
Several Panasonic telephones come with a built-in answering machines. You can leave the telephone as is and let your callers hear a message pre-recorded on the device by Panasonic, or you can personalize your phone with your own greeting.
Instructions below.
  1. Press "Getting Rec" on the base unit.
  2. Press "Getting Rec" again within 10 seconds after you hear the pre-recorded message, "To record greeting, press record again."
  3. Lean in so you are within eight inches of the microphone on the unit, and wait for the long beep.
  4. Record a personal greeting lasting up to two minutes after you hear the beep.
  5. Press "Rec Greeting" or "Stop" after you have finished recording your greeting.
  6. Record your greeting again if the base unit displays an "E" and beeps six times in a row.
  7. Press "Greeting Check" to hear the greeting you recorded.
Hope this help?
Thank you and thanks for using fixya.
Nov 23, 2010 | Toshiba DKT-2010 Corded Phone
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Feb 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
I am unable to record my message on my Uniden DECT 1580 phone. It tells me to go to command 8:RECNEWGREETING. My question is where the hell do I find command 8?? Jesse
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Press /mute on the handset. The system announces the number of new and old messages, and then starts to play the messages unless it has no messages.
You will hear intermittent beeps indicating that the system is in the command-waiting mode.
Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press /mute.
You will hear intermittent beeps indicating that the system is in the command waiting mode.
Oct 30, 2009 | Uniden DECT 6.0 Cordless Phone ID
Trouble recording a greeting message for incoming calls
Go to the RC web site. They might have a manual. You'll need the model #.
Sep 11, 2009 | Lands Phones
Greeting message
On most uniden phones, just hold down the greeeting button for 2 or 3 seconds and you can record a new greeting. You can find your owner's manual online for free in PDF format at Uniden's website
Mar 23, 2009 | Uniden Cordless Phone
Personal Greeting
Go to your personal greeting and press delete twice and press rls this will delete your personal greeting and you can re-record your new personal greeting I hope this helps you!
Jun 13, 2008 | NorStar Meridian 9516 Corded Phone
Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System Logo
18 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
