Akai AP-206 manual - Televison & Video
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
Where do I get set of hinges for dust cover of AKAI AP-X1 turntable
Check on ebay for that tt and maybe someone has parts listed. Or try the manufacturer but if a unit is more than ten years old parts are usually no longer available.
Nov 22, 2015 | Audio Players & Recorders
Where can i find an owners manual for akai ap-l45 ?
First thing to do is contact the manufacturer {Akai}. Next thing is post your question on social media {Facebook, Youtube, etc.} You can also try posting the problem you are having - maybe someone else had it and has a fix for you.
Jan 21, 2015 | Audio Players & Recorders
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
My akai ap 206c direct drive player has just stopped for no reason it seems. Power and all leads are ok.
I have a 206 and a 207 both had dirty pots the speed controllers had to be pryed apart sprayed with cleaner they now work great.I hope this helps.
Dec 31, 2009 | Audio Players & Recorders
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Software doesn't see MSR 206-33USB
Try connecting using the different COM port settings (mine was COM 4). The setting can be changed within the software.
Oct 16, 2008 | Unitech MSR 206-33 (msr206-33) Magnetic...
Need manual
Hi Greg
Unfortunatly, ongoing support for Akai died when the company did about 7-8 years ago. They stopped making non commercial product. So there is next to no on line support from them. What do you need to know about the turn table.. perhaps I can help.
regards
robotek
Nov 11, 2007 | Audio Players & Recorders
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
