Question about Samsung DV5451AEW Dryer
Burning smell samsung dv5451aew - Samsung DV5451AEW Dryer
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Makes Loud Roaring Noise Driving Dryers Problems with vibration
several things to check, the balance of the legs, the rollers or pulley, the tensioner and the belt, and lets hope not the bearings? something caught in between the tub and housing can make strange noises also. might even check the glides on the tub
Mar 18, 2015 | Samsung DV5451AEW Dryer
Does the timer count down on sensor heating
On a sensor drying, timer shows ONLY estimated time to finish. It might add some time, or finish sooner depending on the size of load, fabric, and saturation.
Dec 23, 2014 | Samsung DV5451AEW Dryer
Change heating element Samsung Dv5451aew Front Load Dryer
On most front load machines the first piece that must be removed to access anything is the top. There are a couple of screws/bolts at the top rear that secure it. It then opens, sometimes by sliding it slightly rearward fist to release the catches. Then you can start removing other panels.
Sep 16, 2014 | Samsung Dv5451aew Front Load Dryer
Samsung DV5451AEW electric dryer will not heat up when on any of the "automatic" modes. The dryer dries perfectly when set to a time dry, so it's heating up, but it will not dry when set to normal, heavy...
I would recommend calling a technician. Could be as you said a bad sensor. Make sure the sensor bars are clean. Use an alcohol pad or cloth and clean them.
Sep 26, 2013 | Samsung White Dryer Dv5451aew/xaa
My Samsung DV5451AEW/XAA will not dry cloths. The vent tube is not plugged and air flow is great through the whole vent system. How do I get to the heating element?
  • I am assuming this is electric. Yes?
  • Do you get any heat when there is no clothes in it?
  • Have you checked your voltage at the receptacle? If not 220V, if you have the old tube fuses, then one may be blown. If you are getting good heat with no clothes then replace your high limit thermostat. Lots to check before heading for the heating element. As for heating element they are usually either in the back of the tub or a tube on the right hand side of the dryer. You need to take the front panel off.
Aug 03, 2013 | Samsung White Dryer Dv5451aew/xaa
Burning smell after i replaced lamp
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
Apr 04, 2012 | Samsung HLP6163W 61" Rear Projection...
Screen distorted and burning smell
Those dead resistors that the cause,u are smelling burning plastics.Try website Tvrepairworld.com to buy a whole convergence board for the replacement.The Samsung/Akai are using the same convergence board.
Jun 06, 2010 | Akai PT4250A 42" HDTV
Samsung DV5451AEW Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
