Question about SewShop.com Vacuums
Singer 9020tneed lubrication points - SewShop.com Vacuums
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
How to oil the singer 776 swing machine
Singer sewing machine controls - YouTube
? 3:37
https://www.youtube.com/watch?v=yO3OlJXSoMQ
Jun 26, 2012 - Uploaded by cindylouwho0619
1:54. How To Clean and Oil A Sewing Machine - Duration: 12:07. by Niler Taylor 245,750 views. 12:07. How ...
Winding a Singer Sewing Machine Bobbin - YouT
Dec 09, 2015 | SewShop.com Singer Model 776 Instruction...
I need a free manual for a singer 4016 sewing machine
Try writing to Singer and asking for a manual for your model....or Google the Singer model and include 'manual'. I can direct you to Smith Corona; www.willrepairservice.com. for any part, manual or repair for an electric typewriter.
Nov 16, 2014 | SewShop.com Singer Model 4016 Instruction...
What year is my singer sewing machine? AH251729? how do I purchase parts for it, like the zig zag attachment?
The Singer vintage machine site indicates that the AH251729 was made in 1947 in Elizabeth, NJ. For details see http://www.singermachines.co.uk/faq/tell-sewing-machine-age-from-two-letter-serial-number/ .
Look on the front of your sewing machine and locate the model number of the machine. Go to http://www.singerco.com/support/replacement-parts-chart and locate your model number. (Use the drop down menu and locate the group. Press Go and then find the pdf with the correct model parts list.) You can look up the exact part number and order them from the Singer Service Center online.
Alternatively, you may be able to find them at any Singer Authorized retailer. Just look at your machine and determine the type of shank that connects foot to the machine. (High Shank and Slant are common Singer foot designs on older machines.) Get a zigzag foot for Singer machines with that design. (If they don't have that, you can probably get a current foot and an adapter. We got an overedge foot and the high slant foot adapter for my Singer sewing machine (purchased in 1969) in the 1980s.)
I hope this helps.
(Singer parts are generally available. I saw throat plates for some Featherweight machines this morning at a quilt show.)
Sep 04, 2011 | Singer Vacuums
I have a singer 620 and can't get the bobbin loaded correctly. Can you guide me through?
You have a Singer and Singer has a customer help line that is terrific or you can research your machine online at singer .com if you need the customer helpline I can supply it to you
Jul 25, 2011 | Singer Vacuums
No blockage in my vacuum cleaner but it keeps shutting off during use using an electrolux oxygen
The motor's overtemperature thermal shutoff is shutting down the motor. This is due to
undue load on the motor, from:
(a) bearings have lost lubrication and are about to seize up if you run the vacuum much more, or
(b) there is some resistance to turning the motor that has increased over time, possibly a loss
of lubrication around the beater bar, or turning the impeller.
Either way, finding the lubrication point that needs to be addressed will revive your dying vac.
Jul 04, 2011 | Vacuums
I have a vintage manual singer sewing machine and would like to view a manual
Do you have a model number on the Singer machine? Many Singer sewing machine manuals are available here: http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click search. For example, the manual for the Singer 27 (made in ~1911) and 28 is here: http://www.singerco.com/uploads/download/268_27_28.pdf .
I hope this helps.
Jun 25, 2011 | Singer Vacuums
Want the year machine was made singer ser no. g543008
call Singer direct heres their number Customer Service: 1-800-4-SINGER (1-800-474-6437)
May 21, 2011 | Singer Vacuums
Where can i buy light bulb for singer sewing machine (portable) in manila, philippines
if you know how to take it out you may be able to get a new one from your local electric shop or light shop if not then you will ave to send of to singer unless you ave a local singer store in your country hope this helps to find the singer closest to you look in the manual that came with it if you ave one
Mar 28, 2011 | Singer Vacuums
Vacuums Logo
22 people viewed this question
Top SewShop.com Vacuums Experts
Ron Lake
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
