Question about Berkel 827E Gravity Feed Deli Meat Slicer
Have a fleetwood slicer that does not turn was cleaned uo now it wont start
After cleaning some mirco swith prevents from working
I put my hf2114 on its side to clean the underside. Now it wont start. turn key and nothing happens headlamp works and battery is good. Any ideas?
Does the starter motor turn over or is it completely dead. While cleaning it you may have got water into the seat interlock switch which will prevent it starting.
Jun 16, 2016 | Cars & Trucks
How can I override the auto shut down for a cub cadet?
There is a switch under the seat that has to make contact for the mower to start. I would not advise bypassing it though. A little WD-40 on the switch while working it uo and down will usually clean up the corrosion and get the switch working. If not then replace the switch. It should only cost five or six dollars.
Apr 18, 2014 | Cub Cadet Garden
Not turning on but power light is on
Make sure the bolt that holds the blade cover on is firmly tightened other than that you may have an issue that needs to be addressed by a tech, usually safety mechanisms cause this
Feb 04, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
Car wont start
You need to know if the fuel pump is working.TURN KEY ON,BUT DON,T CRANK engine, Listen for the pump to kick on(should hear it.)IF the check engine light is on,have it scanned. A bad crank or cam sensor could prevent starting.IT could be anything from bad plugs,wires,out of gas, or bad sensors.
Nov 26, 2011 | 1983 Cadillac Fleetwood
To clean can I 1) hose it down with a dishwasher
This isn't recommended, meat tends to get in a lot of the nooks and crannies in a slicer machine. It's best to first unplug the machine, then take it a part in order to properly clean it. If your not sure how to take the machine apart, consult the user's manual for further understand how to do it. Once taken apart, some sort of stainless steal cleaner followed by a sanitizing soap should be used to clean it. Sanitizer is very important especially when dealing with meat products. Once a sanitizer is applied it is recommend that you let the slicer air dry for 4-6 hours before using it again to ensure the sanitizer has fully dissipated.
May 18, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Motor will not turn over. Checked air filter compartment to find 2 oz. of oil and filter soaked.
Not sure if you mean engine will not turn at all (locked) or engine will not start. The engine may have been on its side causing this condition. Clean carb and filter of excess oil. Remove spark plug and clean cylinder and plug of oil that may have entered causing locked condition. Replace oil lost from crankcase. With spark plug removed and kill swith on off, pull rope to blow out oil and verify that motor will now turn. If it still does not turn could be lock rod to crank or faulty pump. If engine had very little or no oil in crank and was run, suspect locked crank, however if your engine has oil senser, this condition would have prevented engine from starting. If you mean that engine will not start, low oil senser most likely preventing start due to low oil. Good luck
Apr 04, 2011 | Honda 2500 PSI Gas Pressure Washer
Why wont my 91 fleetwood crank the battery is good so is the starter
Did you try really cleaning the cables to posts connections. There can be a voltage drop to prevent enuf current flow for such a high demand as starting.
Nov 19, 2010 | 1991 Cadillac Fleetwood
How old do you have to be to clean a meat slicer in the uk
Old enough to know that you unplug it before you work on the blade!
Sep 19, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
I have a 95 cadi limo wont start sometimes pascode key light comes on. I f I take out 60 amp fuse and clean it up it starts
If you have a 2nd key try that. Sometimes the chip within the key acts up. Dont think ''cleaning " the fuse is doing anything.. Possibly removal and reinstallation miight reset
Apr 24, 2009 | 1995 Cadillac Fleetwood
Berkel 827E Gravity Feed Deli Meat Slicer Logo
64 people viewed this question
Top Berkel Kitchen Appliances - Others Experts
john raffaele
Level 1 Expert
Lawrence Oravetz
ray gallant
Are you a Berkel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
