Question about kawasaki PVS-10921 Portable DVD Player
As soon as I turn the Kawasaki DVD player on, no logo display. Just wavy lines like that of the tv's displaying the rolling horizontal lines.
    President:
  • 2,923 Answers
You may need to isolate the problem. Double-check the connection and make sure that the cable is properly connected to the TV.
You may want to swapping the inputs to eliminate the possibility that there is a problem with the video input used by the DVD player.
Or, try power cycling the DVD by turning it off, unplug the power cord from the wall outlet, then turn it back on after 5 minutes.
Try also connecting it into different TV.
If you get the same problem, you may need to bring it to the authorized repair shop for the second opinion or for possible repair.
Hope it helps and have a great day!
Posted on Jun 18, 2009
When turn on shows wavy lines
The screen is probably damaged. It is not worth repairing. Buy a new one.
Aug 14, 2015 | Accurian 9" widescreen portable dvd player...
Display in one line horizontal
You need to change the vertical Ic maybe are burned
Jun 05, 2009 | Progressive JVCXVN222S
Jumping horizontal lines when connected to CD player
Hello, I want you to do a test first. Take you TV and connect a DVD player to it and see if this problem occurs. I bet you it wont, because the problem is not with the TV nor the CD of the karaoke machine. The problem is with the sync pulses of the signal from the karaoky, and the inability of the Tv to sync-up with those signals. What I would use is a video stabilizer between the TV and the DVD player. If the TV still has the problem with the DVD player I would then check the TV for a vertical section problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jan 28, 2009 | Sharp 13VT-K100 13 in. Combo
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
I have a pioneer dv656a dvd player and on some dvd's i play on my samsung ps42q96hd plasma tv, it displays horizontal lines that move from bottom to the top of the screen constantly. Is this normal for a...
Try disconnecting everything from the tv *except* the DVD player (that includes cable tv). You are using a component or digital connection, right? Some of these HDTVs are **** at displaying a composite feed. If this clears up the problem then the lines were probably caused by a fault in your cable tv, and you need to take it up with them.
ANYWAY, if the rolling lines remain even with everything else unplugged, it could also be electrical interference from something near by, like power cords or something.
Mar 24, 2008 | Televison & Video
HELP HELP HELP
lines may be caused by AC pickup. if so, usually the lines move slowly up the screen, and two major sets are usually displayed. wavy lines may also be caused by a local TV station transmitting on the same output channel, either 3 or 4. If you can change the output channel, this may help. Also, try disconnecting all cable or satellite signals and see if the problem goes away. May be an adjacent channel bleeding over. If the lines go away when putting the dvd on pause, the problem is probably in the dvd power supply. Cool the unit down by unplugging it for a while and then try it. If the problem goes away then, separate the dvd player from other devices to prevent overheating
Oct 30, 2007 | Protron PD-800 DVD Player
Koss dvd player
As your DVD is screenless I think you see it on a TV or monitor.Pls make sure the company LOGO is displaying.If the logo is coming--it means video processor is ok--if not try it with resoldering.
Oct 15, 2007 | Koss DVP2161 Portable DVD Player without...
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
May 02, 2017 | Samsung DVD-R4000 DVD Recorder
kawasaki PVS-10921 Portable DVD Player Logo
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
