Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
I have a Dell E510 that will not boot up. It has power and I get error codes 3 and 4. I have reseated the memory and replaced the memory to new memory and tested them one by one in the first slot. The memory is good because I put it in another dell desktop and it worked just fine. I thought it was probably the slot so I bought a new motherboard but still I get the error code 3 and 4. I have also have tried to reset bios. I cant find any other suggestions and this computer is no loner under warranty. Also there are no beeps unless I take all the memory out and I get cerror code 1 for no memory present.
Same problem except I could get it to boot occassionally to a bootable cd with Memtest86 and ram would test fine. Rebooting then gives 3-4 light error code for ram. Leave it sit awhile and reboots to cd fine again. Even got to diagnostics on hard drive and ran couple of hours of tests- everything ok- reboot fails! Found several things to try on other forums: Replace CMOS battery on motherboard Check usb ports on front panel for damaged pins inside Slide voltage selector on power supply from 110 to 220 and back while turned off and unplugged of course. Lastly- apparently the power supplies on the E510 are flakey- capacitor inside goes bad- but that seemed to be associated with flashing amber power light failure. Still worth checking if all else fails.
Posted on May 18, 2010
Bad ram memory stick.
Find by process of elimination and replace.
Posted on Sep 08, 2009
  • 157 Answers
Ok what you might try is get a new hard drive and install windows on there and see what happens. Also if you are able to before you try a new hard drive you should do a system restore and restore it back to the day that windows was installed.
Posted on Jun 18, 2009
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
4 beeps on start up but no screen
four beeps is ram I believe. Take everything off and see if it starts and then put stuff back one at a time and see what is causing the problem
Oct 01, 2013 | Dell XPS 200 PC Desktop
Dell m90 beeping codes
Dell BIOS Beep Codes: Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Mar 03, 2013 | Dell Computers & Internet
I have a dell dimension E510 and it currently will not boot up. The codes in the front panel I am receiving are 3&4. I research and found out this meant an issue with memory module. I removed and...
Try removing the memory module and clean the memory with a soft brush. Clean the slots on the motherboard and place the memory again. Make sure the memory is placed properly. (Both switchs on the memory slot should be holding the memory module in place)
If not working try placing memory in another memory slot on the motherboard.
If still not working, try swapping memory with a computer that has same type of memory.
Try the memory on another computer.
Try the memory of the other computer in the Dell Dimension. By doing this you'll determine waht causes the problem.
Sep 21, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
High pitched beeping sound?
hi!
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution
1-2 no video card detected Reseat the video card
1-2-2-3 BIOS ROM checksum error
1-3-1-1 DRAM refresh error Reseat the memory card
1-3-1-3 Keyboard error Keyboard connector
1-3-3-1 memory card Reseat the memory card
1-3-4-1 RAM failure on line xxx Reseat the memory card
1-3-4-3 RAM failure on data bits Reseat the memory card
1-4-1-1 RAM failure on data bits Reseat the memory card
I hope it match your beep code..
Please rate this help.. thanks..
May 25, 2010 | Dell Dimension 3100 PC Desktop
My Dell E510 PC Desktop Does not turn on, the front light is green, but isn't blinking and a 3 and 4 show up. It also peeps a couple of times, but does not boot up.
Manual is here: http://support.dell.com/support/edocs/systems/dimE510/index.htm
Look under Diagnostic Lights. 3/4 is a memory issue. Unplug your PC and open it up. If you have more than one memory stick, remove 1 and then try rebooting the computer. If it still fails, try the other stick instead. You may need to replace both sticks or even just reseat them both.
Mar 08, 2010 | Dell Dimension E510 PC Desktop
My dell eimension E 510 will just suddenly power down the diagnostic lights 1, 3, 4 remain lit . Sometimes it will work for days, other times it turns off after 2mins.
There could be loose memory modules in the system. Cause the diagnostic lights that you are getting suggest loose memory modules. You can follow the link below to reseat the same .
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
Thanks for using Fixya
Proton
Nov 15, 2009 | Dell Dimension E510 PC Desktop
Computer will not boot
Hi Zany913,
3 and 4 solid green lights indicate that the memory is detected but there is an error. First reseat the memory modules. Then try one at a time.
If nothing happens, I'm afraid you'll need to call dell for replacement RAM.
I hope this helps,
Adam
Jul 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Amber light flashing on dell e510 won't power up
Try reseating the memory sticks.
2. Remove 1 - try to boot
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell E510 Memory
One thing worth trying is taking out the cmos battery (only do this if you are confident you know what you are doing on a motherboard). leave the battery out for at least a couple of minutes and then reinstall the battery (ideally with a new one). restart and you may find you have cured the problem and that your old memory was fine. If this doesn't appear to help (definitely replace the battery even if you think it is fairly new)and jump the CLR CMOS pins. (ask again if you need help on this). second to try is see if you can update the bios drivers from the dell site onto a disk on another machine - use as a boot disk and see what you get. after that i would suspect the power pack, there is no real way to test this without connecting it to another motherboard and seeing if it is fine. alternative would be to just replace it with an equivalent unit, they are not too costly. After this i would suspect major motherboard or bios damage, which may be fixable but is usually cheaper to replace the whole board if you have inserted the wrong type(frequency/size/combination) of memory sets into the board it can often cause this sort of trouble, and often a CMOS clr and reset can solve the problem Please let me know if you need talking through the process - (it is not too complicated, but you can cause damage if you do not know what you are doing) Hope this helps :)
Mar 08, 2007 | Dell Dimension E510 PC Desktop
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
322 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
