Question about Health & Beauty
How to use windmere custom curl 18 rollers - Health & Beauty
My iR 3300 is very slow How can I make speed
dear
pl. do setting for image type to text or text/photo. the curling of paper mostly due to the fixing film unit. the pressure roller may softened. replace it or the path have toner clogged clean it with alcohol.
thanks.
Mar 04, 2015 | Canon Ir 3300 Black & White Copier
Copies come out all curled up.
this could be caused by the lower fuser roller or the paper pick up rollers not picking up the paper correctly worn rollers or rippled lower fuser roller
Feb 01, 2011 | Brother Office Equipment & Supplies
My copies come out curled. Is there an adjustment for that? Brad
Sound more like a paper incompatibility problem. Try another brand of paper, bearing in mind that a laser printer has heating rollers that do tend to put a bit of a curl in the paper.
Jan 25, 2011 | Brother MFC-8860DN All-In-One Laser...
My Ip90 won't feed paper when I try to print a job.
If the paper does not feed properly it could be due to the follwong causes.
Cause 1 : Inappropriate paper type used
Action : * Check to see if the paper you are printing on is too thick or curled.
* Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
Cause 2 : Paper Feed Roller is dirty.
Action : Follow the steps described below to clean the Paper Feed Rollers.
If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
1) Ensure that the printer is turned on and there is no paper loaded in the printer.
2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
The paper roller rotates as it cleans.
3) Repeat this cleaning operation one more time.
4) Load a sheet of plain paper in the printer.
5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
Cause 3 : Paper jams.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
* If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
Caution: Be careful not to touch any components inside the printer.
* If you cannot pull the paper out, turn the printer off and turn it on again.
The paper will be ejected automatically.
2) Reload the paper into the printer and press the RESUME/ CANCEL button.
If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
Paper is not coming through printer and it comes out curled up
Please make sure that any rollers near the exit tray are clean and gripping the paper. The same is true for any paper feed rollers under the cartridge.
Don
Jun 19, 2009 | Office Equipment & Supplies
The paper gets jammed before entering the fuser and curls up. The fuser is new and I have printed no more than 100 copies
What I have seen a lot of is that the lower roller is stalling or not turning. Rough it up with a Scotch-Brite Pad. The upper roller turns by a gear and drives the lower roller by friction.
Jun 10, 2009 | OKI C5100n Laser Printer
Paper curl
Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
If it is the entire paper replacement of the fuser will likely resolve this.
If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
Nov 03, 2008 | HP LaserJet 4 plus Printer
Paper Curling
Your fuser roller temperature may be set too high or if the paper has been sitting for quite some time, you may have moisture built up in the copiter. Usually a service technician can adjust the temperature for you.
Aug 15, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Konica Minolta Bizhub 7235 copies curling at exit. Single or double sided from Document feeder curl almost to the size of a paper towel tube/core
dear friend:1-check the paper and use fresh paper out of wet and stored in dry place.2-use cooling oil and replce oil cartidge in the heater section.3-replace silicone roller (the lower roller in the heater}4-check for smoth movement of exit section(gears-chain-rubber belt}in a good condition replace any defective part.
Feb 20, 2008 | Office Equipment & Supplies
Fusing temperature control
1-if the paper is curling, first thing to do is try fresh new paper.
the one that is there probably has moisture.
2- is the fuser o.k. ? if the rollers are not in new condition they will curl the paper. make sure the bottom roller is shiny and smooth, it is supposed to have a clear plastic on it if it is gone or in bad shape, will give problems.
Dec 11, 2007 | Office Equipment & Supplies
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
