Question about Comfortmaker FVM4X3600A Air Handler, Multi-Position, Variable Speed
Motor speed can i change the motor speed
How do I change wiring on 1080 motor from ac to dc . And what do I use for speed control?
You can't. You buy AC motors to work from a mains supply, or DC motors to work off a battery. You can't alter the wiring to change one to the other.
Wiring a small 2 speed AC motor - Forum - All About Circuits
https://forum.allaboutcircuits.com > ... > Circuits and Projects > The Projects Forum
  1. Cached
Jul 10, 2011 - 6 posts - ‎3 authors How do I wire up a small 2 speed AC fan motor? It has three wires, ... The switch to which it was previously wired had Low and High. It has been ...
[PDF]AC & DC Motor Installation & Maintenance - Baldor.com
www.baldor.com/mvc/DownloadCenter/Files/MN416
  1. Cached
  2. Similar
MN416. AC & DC Motor Installation & Maintenance ... intended only for lifting the motor and motor mounted standard ... regrease or change rusted bearings.
change wiring on 1080 motor from ac to dc Google Search
Jul 13, 2017 | AC Cars & Trucks
Why is my juki machine 8700 not moving at 3000 speed
There are several manuals available, depending on detail and complexity:
JUKI DDL 8700 Manuals
Oct 16, 2014 | Juki Sewing Machines
How do you change speeds on a dayton 3lu87j motor?
did you install the proper motor run capacitor . any time you change a motor you must replace the capacitor
Nov 24, 2012 | Heating & Cooling
We want to change speed on air handler for unit Ruud UBHC-21A00NFA. We disconnected BLACK wire (Hi speed) and put in place of it RED (Lo speed). Is this correct to get Lo-speed on unit? Is there lower...
Hi, It depends on the make and model of the blower motor. You'll need to check this against the schematic (normally located within the electrical cavity) and work it from there. Some are two speed, some three. You can also look at the wires coming from the motor and check those that are taped off. There may be another wire, but check your schematic before changing any of the motor leads to the control board.
Best regards, --W/D--
Apr 28, 2011 | Ruud UBHC Air Conditioner
No control of speed on bench grinder,need schematic
Unless the motor is a brush type universal unit, there is commonly no way to change the speed of an induction motor. There are AC motor speed control units available, but cost more than the grinder as they change the frequency as well as the voltage. There are speed controllable grinders available that use brushes so that simple electronics can control speed. Hope this helps!
Dec 08, 2010 | Craftsman 6" Bench Grinder with Lamp
At its lowest setting, our mixer spins at ever increasing speeds until it stops and then, will not work at any setting.
Your motor needs to be replaced. The speed setting should be able to be set from the start, and if it will not slow down or change speeds, the motor has been over-heated and will need to be replaced. The only quick fix for this is to bypass the speed setting, and change the brushes on the motor. If you do not know how to do this, ask a serviceman to change the brushes only. Brushes usually run about $30 to repair. Although, you will only have one speed.
Nov 16, 2010 | KitchenAid K45SS Classic Stand Mixer
Blower Motor Speed - It was suggested
BJ
I'm using the comment section of the original posting to communicate with you.
Pat
Feb 25, 2010 | 1999 Jeep Wrangler
Change motor speed
if it is afixed speed system, the taps on the motor are: black = hi speed
yellow = med hi
blue = med low
red = low
you may not have a yellow
white is always neutral or comon
Jun 22, 2009 | Lakewood 007 Floor / Box Fan
Comfortmaker FVM4X3600A Air Handler, Multi-Position, Variable Speed Logo
15 people viewed this question
Top Comfortmaker Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Comfortmaker Heating and Cooling Expert? Answer questions, earn points and help others
