Question about Viking Ovens
Viking washer grinding noise on spin cycle - Viking Ovens
  • Viking Master
  • 5,323 Answers
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
viking washer grinding noise on spin cycle - 24140071-iys1iwg4rgvprz2dtg5bqcso-2-0.png
Posted on May 11, 2015
My Viking electric oven is 7 yrs old and recently when I preheat oven , it makes a pop sound ? Is this dangerous?
since it is electric, there should not be any popping noise or sounds. Since everyone has their own idea of what a sound is, I would look into this as it could be an electrical issue of some shorting or arcing.
Aug 18, 2017 | Viking Ovens
Sears front load washer quit mid spin cycle
hi, visit the link below, it has the information you require
http://www.shopyourway.com/questions/1083064
Jun 15, 2015 | Ovens
Viking oven buzzes all the time when not in use
the low voltage transformer on the ERC control is vibrating from not doing anything,when you put a load on this transformer it will quit,only fix is to possibly remove ERC and jam a piece of NON-Flammable/NON-electrical metal to keep it from vibrating and try this first,if this doesn't help,replace the noisy board with this transformer on it
Jan 12, 2013 | Viking 27" Professional Select Built-in...
Seems like the blower motor is making a lot of grinding noise and the fan is not spinning quickly. also the fan continues to spin when the door is open.
the blower wheel has come loose from it's base, this happens a lot with ovens where aluminium foil is used, as the Moffat oven was designed to be the ultimate pastry oven, free flow air system was designed into it, I would start with the blower wheel as it is usually the cheaper of the 2 to buy.
May 24, 2011 | Moffat Ovens
He4 tub won't spin. It fills with water and drains out but wont spin
Hello cnt.... If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Dec 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Viking 27" Electric Oven Noise
Hello. The Viking does have fans which operate continuously to insure even baking. If it sounds like fans running, this is the convection fan operating. J.
Jul 01, 2010 | Viking 27" Professional Select Built-in...
GE WPSR3120WOWW FIRST WASH WORKED AND DID'T FILL BACK UP WITH WATER FOR THE SECOND WASH AND THE SPIN CYCLE WON'T WORK.
Pop the front cover off by using a putty knife to push the clips in (2) at the seam where it meets the washer's top. Pull the thin hose off the left side of the tub and clean it out. (do this with the tub empty) replace tube and front panel and you are good to go.
Explaination: The goop in the tube prevents air from escaping as the water level droped, thus the washer thinks it is still full of water. If it thinks it is full of water, it will not fill any more, nor will it spin.
To prevent this from re-occouring, I'd suggest filling the machine to the lowest level with hot water and adding several cups of bleach. Run the cycle (with no clothes) to help clear out the goop. Use an extra large rinse to make sure there is no bleach residue before doing a load of clothing again. Do this about once every 3 months, and I don't think you'll see the problem again.
Nov 15, 2009 | Ovens
Microwave grinding sound
its not dangerous, if you can stand the noise, it would cost you around $25 to$75 to fix it even if you do it yourself depending where you get the repl parts
Oct 25, 2009 | Ovens
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Ovens Logo
94 people viewed this question
Top Viking Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
