Question about Dell Computers & Internet
Need to plug in the power button to the motherboard but can't find any place to plug it into. My system is a dell dimension 8200.
  • Dell Master
  • 1,684 Answers
The dell Dimension 8200 motherboard like several other Dell boards uses a multi pin header for the power button. This plus is at the front of the board right behind the hard drive connectors. The plus has pins for power, hard drive light, sound, 2 USB ports, power light and microphone. Are you wanting to just coeect the power button and not the other pins? I may be able to get you a pin by pin wiring chart but other things really need to be pugged in too. This board will not work very well without the other things plugged in or if it is not in a Dell case.
Buddy
Corporate Computer
Posted on Jun 18, 2009
What is the maximum ram capacity of dimension 8200 motherboard
2 gygabytoes are usually the max, you could upgrade the OS to maybe Windows XP 64 bit, but this isn't worth it in such an olde machine! Throw it out and get yourself an ASUS laptop with Windows 7 64-bit, a solid state HD and 4 or more gigabytes of ram instead!.
http://www.crucial.com/upgrade/Dell-memory/Dimension+%2F+Dimension+XPS/Dimension+8200+Series+%28400MHz+FSB%29-upgrades.html
Mar 16, 2013 | Dell Dimension 8200 AUD System Board...
Why does my dimension 8200 dell desktop say "strike f1 to retry boot, f2 for setup utility"
Rduy Cruz,
This error message references that your system Primary hard drive is not being Detected in the system. You can press F2 to enter the setup to see if the hard drive is even being seen. If not, exit out and shutdown the system. Unplug the power cable and open the computer to reseat the hard drive cables at the hard drive and at the motherboard connection. If that does not resolve the issue you may need to replace the hard drive IDE cable.If all this does not work you may need to replace the hard drive. Please post back if this does not resolve the issue.Below is a link to your online manual for your computer.
Dimension 8200 Online Manual
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 24, 2013 | Dell Dimension 8200 PC Desktop
Power button on dell dimension 8200 is solid amber computer will not boot up what is it?
hi this looks like the hdd is not powering up...take the cover of the tower and disconnect the hdd power and see if the motherboard fires up on its owen......unplug the power to the motherboard and wait 5 mins plug it back in see what happens.......on the motherboard were you plug in the hdd led cables and power cable and the led cables and fined the one that has the pwr on it plug it in on its owen see if that helps you
Nov 12, 2010 | Dell Dimension 8200 PC Desktop
Need cmos jumper location on Dell Dimension 8200 to bypass bios password
From what I can gather, you just need to locate the jumper labeled PSWD and remove it. Turn computer back on, then back off. Replace jumper pin and turn computer back on. That should do it. Removing the jumper disables password. Turning on computer resets it. Replacing jumper re-enables password capability.
Jul 17, 2010 | Dell Dimension 8200 AUD System Board...
How to replace the motherboard
The procedure to replace the motherboard for the Dell Dimension 8200 is explained in this document under the section "Replacing the System Board":
http://support.dell.com/support/edocs/SYSTEMS/dim8200/replace.htm#1114089
Nov 28, 2009 | Dell Dimension 8200 PC Desktop
Main power button LED is flashing or solid yellow
This is a major problem that crippled Dell. Moels Optiplex Gx260, Gx 280, and Dimensions of whose mdel number i don't remember have this problems. This signal shows that either a power supply or your motherboard is malfunctioning. If you have an insurance better use it now or else get some technical assistance.
Nov 03, 2009 | Dell Dimension 8200 PC Desktop
Broke power button dell dimension 8200
your best bet would be to take it to your local computer repair shop in the hope they are willing to just help you out as it's a very easy repair. failing that ask them if they have a spare switch of the samae type you need and repair it yourself. they normaly have lots of spare bits lieing around they might just give to you.
Jun 15, 2009 | Dell Dimension 8200 AUD System Board...
Need picture of dell dimension 8200 back panel
Here is a link to Dimension 8200 Front view and Back view: http://support.dell.com/support/edocs/systems/dim8200/tour.htm#1101572
The speaker jack is Green.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Dimension 8200 AUD System Board...
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
129 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
