Question about LG LH-T754 Theater System
Can't get into setup on remote control for le home theater system
LG HT305SU remote only working partially. can't get into set up. Rear speakers are not working?
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
SOURCE: I have ATT U-Verse and
well you have the right code, but you have to get the volume options so you can control it. Hold down at&t and the ok button, then let them go. put in code 955 then press enter(bottom right) now you should be able to select whatever device and control that volume source
Posted on May 03, 2009
SOURCE: My LG LBH953 Home Theater rear speakers won't work
You have go to audio setup on the main menu and turn off HDMI. Afterwards, select the sounds button on your remote and select the "games" option. This is because it is probably the best select to listen to movies via surrond sound. I hope this helps
Posted on Jul 17, 2010
AJIN G
  • 6694 Answers
SOURCE: LG HT302SD Home Theater System
HI,
press the sound button on the players remote to select different sound field. select one which suits to you.
ok
Posted on Mar 08, 2011
SOURCE: Need Remote Code for LG LFD790 Home Theater
I NEED REMOTE CODE FOR LG LFD 790 FROM REMOTE GE
Posted on Apr 02, 2011
How to setup my LHT854 to route my LG 42LN5300 TV through the speakers?
You probably need to be a bit clearer as to what you want. But the f (function) key on the unit allows you to change the input To ARC if you have it set up. If you switch off your TV /stereo using the TV remote only this should shut down both. When you turn it on again both should turn on with the sound routed through your stereo ( when you turn on you need to wait a short while while the stereo starts up)
Aug 12, 2014 | LG LHT854 Theater System
I have the bd230 5.1 system hooked up the speakers, attached the power cord and hdmi cable from receiver to the tv what else do I need to get sound from my tv I have a hd cable.box do I need to run a cable...
The home theater box performs the production of the sound generation. Also, the theater box, distributes the sound to any display devices like TVs, Music MIxers, DVDR, VCRs, ext. The theater box also has connection ports that are recognisable as receptacle area from speakers, woofers, and twitters that combined to form the home theater of devices acquired. First, start by connecting the component parts of the theater system to the box. For example, speakers to an area on the box, twitters, woofers. At which point, the box would require a power cable to an electrican circuit to display functionality mode. The next step is deciding on which display reciver would be providing sound to the theater setup of blasters. For example, choosing to acquire sound from a TV set is achieved by connection cables that derived sound out of the TV to the theater box. E.G. The TV audio output area provides the connectivity of any external audio blasters like with the theater setup. Using the appropiate audio input output connection cables to acquire sound transfer matters. The device may not have been provided with a TV audio input out cable of connections. Acquire from retail input output cables from TV to theater boxes. Remember that, the theater box may have come with a remote control that require separe operations than the TV. The theater system theraafter would require power on buttons if any separate remote controls were acquired as well. Also, the television set would require alteration settings with the remote control. Adjusting the TV sound settings to acquire or direct internal sound to an external setup infrusture is possible explanation also achievable with TV REMOte controller soon after every wireing cables have been established alos powered on to source of current. GOOdluck
Jan 11, 2011 | Panasonic Home Theater System System
I cant hear people talking when we play dvd's but we can hear the back round music, how do i fix ths?
I think your front and rear speaker is not working
Please check the speaker cable.
Look for display menu from remote control and set the speaker setup it should be slandered type
Hope this will solve your problem
Regards.
Dec 07, 2010 | Sony DAV-BC250 System
Jun 13, 2010 | LG LHB953 Theater System
LG LHT854 Speaker issue
Have you tried the VSM (Virtual Sound Matrix) button on the remote? I think you will have to scroll through the various sound processors ie..stage...virtual matrix..etc...to find the one that will have all surround speakers working. Hope this helps
Nov 05, 2009 | LG LHT854 Theater System
LG HT963PA I cannot get the rear speakers to work.
Go throught the vsm settings on your remote. This will solve the problem.
Mar 10, 2009 | Audio Players & Recorders
Wireless speakers won't connect
You try upgrade the main set to 5.1 or 7.1 channel is it?
If the wireless is green light mean the main set is recognize the wireless.
You need to setup the speaker output from main set by "Setup" button on remote control.
Can refer Operating instruction manual in main set.
Nov 29, 2008 | Panasonic Home Theater System System
Help With My Rear Speakers
Just clicked on sound effect on the lg tv remote it was set to 2.1 changed to 5.1 and the system came alive!!
Oct 07, 2008 | LG LHT854 Theater System
RCA Home Theater Model RTD215
cox digetal cable universal remote will not work with this system now i have 3 remotes for tv,cable, and now my home theature system
Dec 27, 2007 | Televison & Video
LG LH-T754 Theater System Logo
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
