Question about Vizio VBR220 Blu-Ray Player
Vizio reads disc then opens door - Vizio VBR220 Blu-Ray Player
My VBR-110 Vizio Bluray player says no disc when there is a disc. I've cleaned the disc, tried different discs, cleaned it, unplugged it for a long ass time, so I don't know what else to do.
It's the laser that is faulty. The laser retrieves information . Normally when you load a disc you will hear it speed up then slow down and as the laser reads the disc it sort of makes a noise like a small hiss or squeak.
i imagine yours will take the disc and then runs to full speed and after around 30secs you have the error message and it stops? . Depending on how your model loads the disc this can sometimes be the result of someone pulling open the drawer or pushing it shut. If it's self loading try getting a good disc cleaner .
They cost very little and it may be enough to clean the laser lense. So buy a basic cd or DVD cleaning kit . The disc will have small brushes on it to clean the laser .
Good luck
Dec 10, 2013 | Vizio Televison & Video
Vizio vbr133 player . player starts to load disk and then reads no disk. tryed with different disk still reads no disk. error code HON7E
I was getting the same error and I could not get regular dvd or blu ray discs to play either. I dug out my old cd player lens cleaner and put it in and it started playing. I let it clean the lens for a couple minutes and now it is playing my movies again.
Jan 01, 2013 | Vizio VBR133 3D Blu-ray Disc Player
Disc error
It means either the optical pickup trying to read the disc is dirty or bad.
If bad--it may not be cost effective to repair that unit.
Apr 03, 2012 | Vizio VBR100 Blu-ray/HD DVD Player
Disc door will not open
hello,
the reason the disc door would not come out is because there is a problem withe the mechanism that opens the door.
to fix this,
1. you unscrew the dvd player,
2. take off the cover,
3. plug the dvd and press open to see if the door would open, then you will see where it is getting stuck,
4. replace the mechanism that is controlling the disc door, and press open to see if the door will open.
5. once it is able to open up, you can screw back the cover.
Jun 02, 2010 | Memorex MVD2040 DVD Player
The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
Jan 22, 2010 | Microsoft Xbox 360 Console
My dvd player won't read disc, the door keeps
change the motor belt charge it´s located downside the disc tray
Nov 09, 2009 | Apex Digital AD-500 DVD Player
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Cd drive door will not open. when opened manually and disc inserted door will not close automatically and will not read a disc
Is there any power to the drive? IE is there a green light on the front when trying to read the disk?
It may not have the power in, or may have blown a power circuit.
IF it was just the door not opening and the unit has power, i would suggest the little rubber band is having issues and not opening or closing the door.
Dec 18, 2008 | Computers & Internet
Play station 2
Looks like a hardware problem. Send it in for repair.
Dec 07, 2007 | Sony PlayStation 2 (PS2) Console
Vizio VBR220 Blu-Ray Player Logo
26 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
