Question about Dell Studio XPS Desktop Computer
Yellow blinking light on power button
Unit does not power up, but the power button blinks yellow when I push it
  • Dell Master
  • 998 Answers
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Posted on Jan 03, 2015
SOURCE: Yellow blinking power button
A customer of mine has several of these that have the same problem. I found a comment on a Dell forum indicating that one of the capacitors on the mainboard will be either swollen or leaking. Replace the capacitor and it should be OK. I do not have the proper equipment for soldering on a mainboard so I have not done this. However, I did a google search on "Dell SX280 mainboard purchase" and I found a guy on ebay selling the repaired boards for $100.
Posted on Sep 18, 2008
Bappa170873
  • 505 Answers
SOURCE: power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Posted on Oct 11, 2008
eagle338
  • 4889 Answers
SOURCE: dell dimension 4700 blinking yellow light
You clearly have an SMPS(power supply issue). Not 3 days ago I worked on my dad's PC that had the same problem. I found that the board had some leaky caps, and the circuit board inside it partially burnt. I could get it working by replacing the caps, but dont know how long it will last(I'll be getting a new PC soon anyway). Its advicable you replace the power supply. Should cost you around 30-50$ at MOST!
Posted on Apr 08, 2009
mrninja
  • 600 Answers
SOURCE: Dell Dimension 3000 yellow light blinks, PC will not start
could be a bad driver..try booting into safe mode F8
Posted on Apr 12, 2009
  • 4 Answers
SOURCE: My dell xps wont start properly, yellow blinking light
I have an HP that does close to the same thing. Mine goes into a 'Perm-Sleep' mode that I can't seem to pull it out of. I have to remove the battery, then unplug the power adapter, not in that order. Leaving it in this condition for about a minute so that all the power stored in the RAM goes away. This is the same as holding the power button down for 10 to 15 seconds until it completly turns off, sometimes referred to as a 'Cold Boot.'
Once I have powered it down I have to go into the control panel and select the power settings and make sure that hibernate is not an option. If you close the lid on the laptop and the systems goes into a sleep state, it may be configured to go to hibernate after, say an hour or when the battery gets close to being drained. My computer does not like to come out of hibernate and I have to Cold Boot it, so I just don't let it go into a hibernation in the first place anymore.
Posted on May 10, 2009
How do I clear a yellow light on my Scotsman ice maker?
Front panel has cleaning procedure if followed correctly it should of came off...if not quick way push clean let run 2 min sump full light has to be on push and hold clean button for 4secs blinking amber light should stop blinking let run for 2 mins.then push and hold until dash comes out unit shuts down and light is off... push green button continue to make ice
Dec 02, 2014 | Kitchen Appliances - Others
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
Light blinks red then turn on and blinks yellow once and back to blinking red
YLOD (yellow light of death) Replace your power supply inside the unit. Can pay Sony $150.00 USD or spend $40.00 USD on E-Bay. Very easy to install. Google PS3 YLOD Repair for indepth instructions.
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
Dell? OptiPlex? SX280 blinking yellow what is that
blinking yellow light on the power button of a Dell system is a possible power supply issue. press the eject button on the dvd drive while the power button flashes yellow light. if the disc trays wont come out, you need to replace the power supply. hope it helps. good day.
Jan 07, 2010 | Dell OptiPlex SX280 PC Desktop
Dell Insp 4600C blinking yellow power light
the issue could be woth the power supply unit or internal wirings ..
Jul 19, 2009 | Dell Dimension 4600C PC Desktop
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dell Studio XPS Desktop Computer   Logo
126 people viewed this question
Alun Cox
