Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Grinder jammed Grinder is jammed on my Saeco Primea Touch plus. Need step by step disassembly instructions. Any suggestions? This thing has more parts than the space shuttle. I have the exploded view of parts already.
  • normrx7 Jun 20, 2009
    Took care of the problem myself-I threw the damn thing out the window! Kidding, however I did follow the exploded parts view very carefully and patiently to disassemble the machine and found a bit of metal jammed in the grinder assembly. The thing seems to be working fine now, thanks.
  • 20 Answers
I'll explain how to in general, you have to work out the rest...first remove 3 screws on the coffee container...and 3 again underneath.To remove the sides..undo 6 T10 screws on RH side and 3 on LH.Then pull the front knob off and remove the coffee spout.Remove the top cover.Check the grinder whether itis accessible from the top ,if not remove 5 phyllips screws that hold the top half.Lift up and pull the grinder out. Good luck!
Posted on Dec 16, 2009
What is problem of coffee grinder not working
if the machine is ready to go and the grinder not start check to see if is not block the grinder blade and if not block change the grinder with the same voltage one 120V or 220V
Feb 18, 2015 | Saeco Primea Cappuccino Touch Plus Coffee...
Error 1 - How to Resolve Grinder A Blocked?
The grinder is the problem. Inside the grinder is a white gearwheel. Change the gearwheel (cheapest way) or change the grinder and reset all errors from service menu.
Jun 05, 2014 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino must be reset I recive error mesage : error 1 I replaced grinder with a new one but the error message remained on screen and do not know how to reset
Hi,Ive just recieved an email saying that your having some problems with your machine. Its hard to keep up with all the error codes on the hundreds of machines on the market. Faulty grinder usually dont give an error code. The grinder will just not work if its faulty, which tells me theres a problem with grinder. If your showing an error 1, i'd be looking at the steam heating circuit. Faulty thermoblock, thermostat, solenoid, etc. Anyway, something has led you to replacing the grinder, so ill see if I can help. Some machines need to be told that it has been fixed, which is done through the programming. You know when you go in to the cleaning program, thats where it may have to be told. The grinder also has other electrical sensors which maybe at fault. On one of the wires that connect to the grinder is a little square thing that sits in a holder on the grinder. It maybe faulty.(not common fault that part). The machine will usually reset itself when you turn it off at the main toggel switch, and unplug it from the power point. When you turn the machine back on, it will do a self dianostic before it starts to heat. but as I said before, the grinder usually isn't part of the self dionostic on start up. If you turn it back on and error code comes back up, id be looking at thermoblocks or thermostats. If your still having troubles, give me more details on how the machines full operation is working. If the grinder is at fault, everything else should be working. Thanks Darryn
Oct 08, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Error 1 message on lcd screen. What does this mean?
That means the grinder motor is not working, have to take it to the service center to replace it.
Jan 07, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Error 1 on saeco primea touch plus
The grinder motor is not working,,better to take it to the service center to replace a new one under warranty if the machine is new.
Oct 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Touch Plus flow problem
In the bean hopoer there is a little screw. Remove this screw and the cover and you will see an adjustment alan key. You need to push down and rotate the adjuster counter clockwise to make it finer and clockwise to make it bigger. Make sure you only rotate the grinder a little at a time, 1/4 turns at a time recommended. Make 2 cups then readjust if necessary.
Saeco Authorized Sales & Service of Espresso Machines
www.CeriniCoffee.com
Nov 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Flow
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
Nov 23, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
367 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
