Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Door latch on Whirpool Energy Star dishwasher #8575637 is loose but door does close; however dishwasher does not start or fill with water.,
  • 159 Answers
SOURCE: DU1100 XTPS DIshwasher
I would make sure that the lever on the dishwasher body is not bent in any way. If it is you can straighten it out and then make sure the door close's properly. But for being 3 months old I would give whirlpool a call and have them send a repairman out. There will be no charge to you seeing its under there warrenty.
Posted on Jul 22, 2007
  • 90 Answers
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
are there soap suds coming out of the door?
Posted on Jan 06, 2008
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
  • 185 Answers
SOURCE: Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Posted on Apr 08, 2008
SOURCE: dishwasher door won't latch closed
Please tell me, did you find out what's wrong - because this has happened to me now. :(
Posted on Feb 25, 2010
Why is door latch stuck in open position and will not latch closed?
Hello. The door switch, part# DD81-01629A, may be broken. See attached link for pix of the part. Let me know if you need further assistance. Thanks!
Google
Nov 28, 2015 | Samsung DW80F600UTS 24" Stainless Steel...
Whirpool dishwasher not drying with heat
The heating element is bad,if it is getting voltage yet has no amp draw it is bad.
Apr 07, 2015 | Whirlpool Whirpool Energy Star Dishwasher...
Why won't my portable dishwasher work?
Recommend check door closed and not blocked; sprayer not blocked, dispenser not clogged, door latch locking and latch sensor connected and conducting.
Dec 31, 2014 | Danby "DDW1899WP 18"" Portable Dishwasher...
I have a whirpool energy star washer and the door is stuck in lock position. The lights that are on are spin and door lock
If you remove the bottom panel under the door, you can see a lever or tab that will allow you to open the door. Before you do that though, there is a drain plug that is visible. Remove the plug and get ready for WATER to come out. Have towels or wet vacuum cleaner ready. There will be a filter trap that is in the drain. Clean it out too.
Nov 28, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
How do I clean dishwasher its starting to leave whiet spots on dishes
Good Afternoon Friend,
I understand you want to know how to clean your Frigidaire dishwasher, model# PLD2560LCC, as it is starting to leave white spots on your dishes. Please follow these simple instructions:
1. Load your clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes). The SENSING light will be off.
5. Unlatch and open the door and pour 2 cups of white vinegar into the bottom of your dishwasher.
6. Close and latch the door and allow cycle to finish.
Note: If these conditions persist, a home water softener should be considered.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
Clear water left n bottom of dishwasher
Check drain and pump. If the water goes to a garbage disposal then remove the hose at the disposal and see if it is clogged.
Good luck,
Marty
Mar 23, 2013 | Whirlpool Whirpool Energy Star Dishwasher...
Wil not fill with water
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
  • The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched. The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
    If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
    It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch
    Sep 21, 2008 | Dishwashers
    Kenmore..Few years old came with the house
    Check the spade/lug wiring connectors under the unit at the motors They can work loose. These newer units only use the heating element for a short time. If you get it running again do not use tablet soap. Start your sink's hot water until its too hot to touch then start the washer, let the tank fill then open the door and pour in an additional gallon of hot sink water mixed up with liquid cascade soap. To get "Energy Star" compliance, They have made trade offs to use less water and energy. When mine is running it still doesnt clean very well at all. consider installing a small R.V. water heater under the sink or nearby.
    Also make sure your drain hose is clear and has no kinks in it.
    Jan 01, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
    Whirpool diswasher DU929PFGG2 wont draw water
    The pump may be clogged or the motor start capacitor may be bad or the fill switch may be stuck or the timer may be bad. Fill the dishwasher by hand to just below the door level and close it then see if it will run. If it then runs correctly the problem may be the fill switch. If not, it could be the motor, the cap, or the timer
    Nov 30, 2007 | Whirlpool 24 in. DU930PWP Built-in...
    Clean light blinks
    Raise the temperature of your water supply. To reset computer open door,within 3 seconds hit hi-temp scrub then energy saver then repeat this. Close door and latch, push cancell button.
    Jun 10, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
    Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
    42 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
