Question about ASUS Intel I5 Win 8 Nvidia Gt640 ASUS
GT640 produces colored transparent layer over video
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
You can try updating the latest NVIDIA driver from Nvidia support site.
if problem persist then call Asus engineer at your place and get it fixed.
Posted on Oct 04, 2014
Trying to make some decals with text on it but need the back ground trasparent then save as tga or dds file cany any one help
You can accomplish this by creating a new layer and making it transparent and putting it at the bottom, then using another transparent layer above that one make your text and decals or import them.
Mar 13, 2011 | GIMP GNU Image Manipulation Program
How to change back ground color of an image?
Too many varibles ,but I'll give it a try. are there any layers? does the background layer ( the one called background at the bottom of the list in the LAyers palettte) have anything in it? area all the visible layers above the "background" transparent where they are "white"? If this is the case it's much easier than if any of the layers are "white" or some other color- then you need to select out the items you want not to change color, using any number of the available "selection" tools, from the area you want to change color- now that can be a challenge.
Jun 02, 2010 | Adobe Photoshop CS2 for PC
Dear All I would like to know if I can use my HPDeskjet 5550 to print onto Overhead Projector transparencies or are they likely to melt inside the printer. A bit dated I know but I have to give a...
Hello ,
Of course you can.
While printing set it in advance printing options, the paper type the print quality and others setting corresponding to your needs
Regards
Uttam
Feb 19, 2010 | HP DeskJet 5550 InkJet Printer
Cut image and transfer to transparent background using gimp
Hi Jody,
Gimp can be frustrating, but it's one of the most amazing and powerful free applications out there. You're right...what you're trying to do is very simple, but you need to know a few tricks to get it to work well.
First, you need to use .PNG as .JPG files don't support transparency. When you try to save a file in .JPG that has a transparency, or alpha, channel, you should be prompted to "export" the image by flattening all layers, which essentially replaces all the transparent areas with the current background color (usually white).
Second, there's a tool that's been added to the most recent versions of the Gimp that does exactly what you want to do. It's called the "Foreground Select Tool" and is really simple to use once you get the hang of it. This tool was added in Gimp 2.4, so you'll need at least that version or higher to use it. This tool uses a two-step process: first you draw a rough circle around the object you want to cut out (your daughter), then you "paint" over the foreground object so the tool can sample all the colors you're wanting to extract. This sounds strange until you do it...once you understand, it's really pretty simple. You can read the docs for this tool here. There's also a YouTube video that shows the basic process. Apparently no sound on that video, but at least you can see what to do.
Not sure what was happening when you tried to use the scissors. There are so many variables, it's hard to tell. You probably didn't need the extra step of adding a transparent layer...when you had your selection copied to the clipboard, you could have used "paste into" or "paste as new layer" or "paste as new image" to get what you want.
Let me know if this doesn't answser your question.
Eric Imboden
http://commoncontext.com
my take on tech : http://redsquiggly.com
Mar 10, 2009 | GIMP GNU Image Manipulation Program
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Gifs with white backgrounds
1. open in Photoshop
2. Windows --> layer. Then double click the layer there, click OK the dialog box so that the "background" become "layer"
3. Select the white background. You can use magicwand tool, or if the object you want to keep is not white, you can use "select color--> white"
4. Edit --> clear.
5. safe as gif
Feb 03, 2008 | Adobe Photoshop imageready 5.5 for PC
Game
tune down the settings in game. example: changing screen resoloution from 1200x1000 to 800x600, also decreasing the quality may help. another thing you can try is exiting ALL applications that are running while the game is running that are not needed, such as any downloading clients or anything that may be using up some of your computers processing speed.
Sep 12, 2007 | Video Game Consoles & Games
ASUS Intel I5 Win 8 Nvidia Gt640 ASUS Logo
19 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
