Question about Dryers
Gas smell Propane gas dryer smells like gas when dryer not running
  • 74 Answers
SOURCE: Dryer smells of natural gas
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Posted on Jan 18, 2006
docjohn174
  • 943 Answers
SOURCE: Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Posted on Sep 18, 2008
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
erpaalai
  • 999 Answers
SOURCE: Dryer smells like gas
If you smell gas then there is a leak. The gas company came out and checked for a leak? Get them back in the morning before you open the room to check again. Eric
Posted on Aug 27, 2009
  • 3640 Answers
SOURCE: gas smell inside maytag neptune gas dryer
first of all, check to see if dryer vent is not plugged.
Posted on Jan 14, 2010
Whirlpool wgd9400swo. Gas clothes dryer The burner only stays lit for 1 minute the new goes out, tries to re-light but can't seem to
The limit switch is bad. most likely or the igniter. Does it give off a gas smell? If it is propane you can really smell it. But Natural Gas You may not.
Nov 08, 2016 | Whirlpool Dryers
Smell of propane
call the company back explain to them about the smell and where you smell it and would like another test of the lines and appliances that are hooked up as to your medical seek a doctor
Apr 19, 2017 | Heating & Cooling
Smell propane after I ran out and filled it back up> I replaced the regulator behind the stove but still smell propane
It is not uncommon to "smell" propane when you run out. Propane has an odorant called mecapitan added to it so you may detect it. When you get low or run out the mercapitan is typically in greater volume than the gas itself. Once you refill, you will also smell it temporarily. Check all connections for tightness and leaks, use a leak solution, and if all is well, start it up and monitor it. The odor should dissipate. If it does not, contact your local licensed propane technician.
Jan 16, 2014 | Tappan Kitchen Ranges
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Is it normal to get a faint gas smell when you hook up you'r gas dryer?
Absolutely. Your dryer runs on gas, and the gas kicks on when the heating element engages. It should be so faint though. If you smell it continuously then check your connections with soapy water, if their is a leak then shut off the gas and try using soap pipe dope, or teflon tape on the threads, then recheck. My guess is its the regulator near the heating element. Good luck
Feb 21, 2011 | Kenmore 77632 Gas Dryer
Converted to propane ,installed turned on seems to heat etc properly but smell gas
Propane will often give you an odor even though you have done everything correctly...just spray all connection with soapy water to make sure you don't have any leaks...
heatman101
Sep 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Convert propane hook up for dryer back to gas
the oriface size for propane and natural gas is the same it only has to be changed if you will be useing butane it should hook up and work the same but the propane will have a stronger sulfer smell than natural gas always connsult you gas provider if you are concerned they usualy will send tech to inspect if youhave questions for your safety
Nov 17, 2009 | GE Profile Harmony DPGT750EC Electric...
It smells like something is burning smells like the gas is not burning very harsh odor that burns your eyes after a period of time
If it smells like an incomplete combustion smell, clean the burner first. I'm assuming it used to work and now doesn't? If it never worked correctly it may have the wrong jet in it. There is a jet for propane and one for natural gas. They do not interchange. If it smells like plastic burning, something probably got past the screen and fell into the burner.
Sep 28, 2009 | Dryers
ELECTRIC DRYER SMELL LIKE GAS
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Jan 31, 2008 | Dryers
Gas smell
Fire Hazzard ? YES !! Sounds like the ignitor is taking too long to lite the gas. This lets the gas trickle into the machine. It is very important to the operation that the ignitor lite within 30 seconds on the first try and within 20 seconds thereafter.
Dec 10, 2007 | Whirlpool LTE6234D Top Load Stacked...
Dryers Logo
14 people viewed this question
Top Dryers Experts
