Question about Miele Optima G2470SCVi Built-in Dishwasher
Intake/drain light comes on, and beeping alarm sounds, when I turn on clean cycle
When I turn on dishwasher, beeping alarm goes off and intake/drain light illuminates.
  • 14 Answers
SOURCE: Intake/Drain red light comes in and shuts down during wash cycle
You will more that likely have a faulty waterproof inlet system
Posted on Sep 13, 2007
  • 9 Answers
SOURCE: Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Posted on Apr 20, 2008
SOURCE: Intake/drain light flashing
I have (had) the exact same problem with my Miele. Here is what (appears) to have fixed it:
1) Disconnect the inflow line at the water source. Its the connection that looks like a garden hose. Use a screw driver to remove the washer inside, the pull out the little filter with needle nose pliers. My was clogger with particles from the washer. Clean with soap and a tooth brush.
2) Disconnect the outflow line at the garbage disposal. My was moderately clogged with food (Note: my son overfilled the garbage disposal before running. It may have backed up).
This worked for now at least. Remeber, as irritating as red lights can be, it prevents the motors and pumps from burning out when you have clogged plumbing.
Kerry
Posted on May 22, 2008
  • 3 Answers
SOURCE: Intake/drain light blinking on Miele G841 dishwasher
I cleaned out the drain pump and non-return valve on my Miele G658/858 and that fixed the problem. The G841 may have similar parts. It's easy to do. In order: 1. Turn off washer. 2. Remove the triple filter (the basket on the bottom of washer with the little handle. Turn the handle and remove) rinse out and set-aside. 3. Remove the standing water. I used a wet vac to remove the standing water from the bottom of the machine, but you can scoop it out also. 4. Tilt the locking clamp (tilt left) to the side. (this is a metal wire covering the white plastic valve. This valve is to the right of the triple filter basket.) 5. Pull out the non-return valve and rise will under running water. You may have to wiggle the valve a little. Pull straight up and out. 6. The drain pump is beneath the non-return valve. (it has a little plastic propeller, like a paddle wheel, inside) 7. Spin the propeller several times in both directions to make sure it's clear. ( I used the shop vac with a small hose attachment to clear the drain above the propeller compartment) 8. Carefully refit the non-return valve and secure it with the locking clamp. 9. Refit and lock the filter in place.
I haven't had a problem since and my dished are much cleaner- The problem must have been coming on for a long time.
Hope this helps,
Susan
Posted on Oct 08, 2008
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
Intake/drain light on
Please check the INLET water pressure, remove the inlet and check. Now if there is pressure make sure that when the power is pressed there is a pre wash cycle to start the machine. If not there is fault in the program controller , please check the door switch and the panel board.
Jan 02, 2013 | Miele Optima G2470SCVi Built-in Dishwasher
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Intake Drain light on and water in the bottom of the dishwasher
sounds like the flood mode is in operation, you may have a leak into the base stopping the wash continuing. pump out the water, then tip the unit at about 45 degrees and see if any water pours out of the base- confirming a leak.
Jan 03, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Hello , The inlet/drain light on my dishwasher is flashing , I have mislaid the manual can you explain how I can rectify the problem please , I am assuming something is blocked. Regards Georgina Cooke
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
Jun 24, 2009 | Miele G892SC SS Dishwasher
Intake drain light flashing
1. Unscrew air gap which is on the counter-top next to sink.
2. Unscrew drain clamp under the sink which s connected to the air gap.
3. Use a wire hanger to push down debris clogging the drain.
4. Screw clamp and air gap back in place.
5. The dishwasher should work. Routinely clean out air gap every half year.
Jul 30, 2008 | Miele Dishwashers
Loud noise when unit is pumping
Sounds like it is not getting enough water. Try adding water to it to see if the sound goes away. Start the unit at the begining of a cycle, open the door after it has started to circulate and see where the water is at. If it is low then you have a problem with the amount of water coming in, possibly the waterproof (valve) is going. If the level is good and it happens later in the cycle, it could be a drain issue. You may have to get in a tech.
Sgt 48
Jun 03, 2008 | Miele 24 in. Novotronic G842SC Built-in...
I had the same problem. Switched to powder detergent instead of liquid and the problem was solved! Hope it works for you.
Nov 11, 2007 | Dishwashers
May 17, 2007 | Miele 24 in. Novotronic G851SC Plus...
Miele Optima G2470SCVi Built-in Dishwasher Logo
120 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
