Question about Toshiba E-Studio 161 Copier
Workcentre m20i reset drum warning - Toshiba E-Studio 161 Copier
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
How to by pass the toner empty warning on xerox m20i so I can use the remaining toner?
You can try shaking the cartridge a bit from left to right. If this doesn't work, you will need to order a new toner.
Jun 13, 2014 | Xerox WorkCentre M20i All-In-One Laser...
Replace drum
replace your toner and drum cartridge with a new one
Dec 11, 2013 | Xerox WorkCentre M20i All-In-One Laser...
My printer has this error: Drum warning! what should I do? What should I replace? Thank you!
"Drum Warning" error indicates that the drum is running out. I think you can still print or make copies, but it will not last long and will run out very soon, at that time, you have to replace the Drum.
Hope this helps.
Good Luck.
Thanks for using FixYa.
Dec 13, 2010 | Xerox WorkCentre M20i All-In-One Laser...
My m20i still says toner low after i replaced it. Is there a reset button I need to press somewhere?
toner or drum?? if toner the chip may be defective or wasnt changed at refill. if its the drum, print the help page to guide you to that section. and reset.
Oct 12, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Copying problems
You must change the power supply
Apr 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Cannot fax using my Workcentre M20i
The machine itself can not give that message. You have some tye of phone line issue.
Feb 11, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Toshiba E-Studio 161 Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
