Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Repair install needs Location of NT5inf.cat - Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I have an older cat eye computer. Wires. The cadence function stopped working. All other functions are good. I installed a fresh battery, I adjusted the sensor location. Still does not count cadience
If you take a magnet and pass it right by the sensor several times and get no cadence count then the wire is broken or the cadence portion of the computer is non-functional. Unless it's the wire and you can fix it you need to buy a new computer.
Aug 16, 2017 | Cat Eye Cycling
Windows Xp Service Pack 2 NT5INF.CAT Error
Dial our toll-free number 1-877-227-5694 to resolve your query related to Windows Xp, Our technical support team resolve your query instantly.
Aug 08, 2017 | Computers & Internet
How to change an oxygen sensor on a 2006 Buick rendezvous
The trouble code should tell you which 02 sensor? The 02 sensors are in the exhaust, sensor 1/sensor2, whatever, bank 1/bank2, whatever, before the cat, after the cat. You have several 02 sensors in the exhaust, don't know which one?
You should be able to remove/install with proper size wrench or deep socket. They do make an 02 sensor socket that has that slot in it, not sure if you need that, though.
Jan 25, 2016 | 2006 Buick Rendezvous
I need help to confirm location of sensor 2 bank 2. CEL detect P0161. There are 4 sensors in which two are above the catalyc converter and two are below the converter. The part department staff says the...
that Toyota has a 2.4 l 2az-fe 14of 155 hp and ran from 2001-2007 after which a v6 engine was installed
the sensor is the one before the cat converter as it is a heated oxygen sensor (KO2S) and reports on the gas composition to the ECM for air/fuel ratio adjustments
the oxygen sensor (O2) is after the cat converter and reports on the cat operation
have the cat converter checked at an accredited muffler shop
Jun 21, 2017 | Toyota Highlander Cars & Trucks
Hooked up battery backwards must have blown a fuse where is it located 05 yzf
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic Where the fuse box
yzf600r main fuse location Google Search
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Dec 06, 2013 | 2005 Yamaha YZF 600 R thunder cat
My computer say, the file NT5INF CAT ON SERVICE PACK 3C D IS NEEDED...and i dont have any dics to my computer can you help please
If you are talking about XP Service Pack 3 then ebay will sell the disc or you can download SP3 from Microsoft as an ISO and burn it to a CD.
Mar 22, 2011 | KDS Valiant 6370iPT Notebook
Where are the oxygens censors located on a 1999 Acura CL 3.0, need to replace them
The 3.0 is an ODB2 car so it has 2 o2 sensors. One before the CAT and one after the CAT. Check your headers for the primary heated o2 sensor location, and check on top of the cat for the secondary o2 sensor.
Sep 07, 2010 | Acura CL Cars & Trucks
Need to know location of Bank 1 Sensor 1 on engine
If I am not mistaken bank one should be your driver side. However your sensor one will be before the cat converter. So you just have to find the o2 sensor before the cat converter on the driver side. Good Luck.
Oct 12, 2009 | 2003 Acura 3.2TL
Oxygen sensors
Here is the location of the O2 sensor, Under hood, center, lower engine area, rear center of engine, mounted in exhaust manifold
and here is the location of the PVC valve, Under hood, center, upper engine area, mounted in intake manifold
So to your problem there is only one oxygen sensor according to your repair guide. If you need any other info on parts and location you can try Auto Zone .com
Jan 10, 2009 | 2000 Nissan Maxima
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
