Question about Eagle Boating
Doesn't read in deep water - Eagle Boating
Can you soak heating element on a butterball electric turkey fryer?
Most heating elements are indeed submerged in oil and for that reason I would not think it would affect your unit, however I do not normally work on home model products. I am a commercial restaurant equipment dealer, working on commercial products only. Trying it out would tell with within a few minutes whether it's going to work or not? Any other questions, I would find the 800 number or website for that company and ask them directly. Sorry I couldn't be more help to you, but I just don't know that much about home model stuff.
Susan Restaurant Equipment Outlet, Cincinnati, OH
Nov 15, 2011 | Kitchen Appliances - Others
My drive doesn't read all dvd that i inserted
There can be some reasons for this behavior:
1. If those are movie DVD's from a region that your player is not unlocked to play, it won't play it.
2. The DVD's have deep scratches.
3. There is some problem with your DVD player itself. You can get it repaired but its best to buy new.
Aug 15, 2011 | Computers & Internet
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
I have an ecosmart Fisher&Paykel. Goes OK through all the cycles until the spin. Won't empty water. Tried rebalancing load, and it is level. Manual says it could be a suds build-up and to do a deep...
Hi there, it sounds like your drain pump is not working. Tip the washing machine back and look underneath. The drain pump has a little black fan on it. Disconnect the hose to see if there's anything stuck in the drain, like coins, hair clips etc. Clear out the pump and remember to reconnect the hose securely before trying out the washing machine.
Please remember to rate this solution, thanks.
Jul 01, 2011 | Fisher and Paykel Washing Machines
Simpson esprit 450 washing machine timer not working. It statrs at a certain point (rinse) but doen't work when I set it for wash. It does rinse, deep rinse and spin but doesn't wash at all.
Hi just read your posting.Now just a couple of questions.What water temp have you set the machine for,Is it cold,cold or another setting.Have you got the cold hose going from the cold tap to the cold water valve on the machine with is marked with a C and the same for the hot which is marked H.Please reply with answers to all the questions and I am sure I can help you with this fault.Looking forward to your reply.
May 24, 2011 | Washing Machines
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered):
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
Water doesn't come out of my Bissel Deep Cleaner
Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Won`t start
o no! how deep?
my have sucked in water!
remove plugs, turn engine over water might come out of plug holes .
change engine oil also,maybe should do this before trying to start it any more. take off cap and rotor and dry off. try watching plug wires . if they spark in the dark when trying to start they are worn out and soaked with water and shorting out to the engine. check fuses also
Apr 27, 2009 | 1996 Volkswagen Jetta
What is the "kettle"?
The kettle is mentioned as the fry pot just different slang.
Nov 06, 2008 | Pitco Frialator SG14 Deep Fryer
Epson 4800 set ink crtg error
Check the following information for reset the printer cartridge.......
http://www.fixya.com/support/t2689003-set_ink_cartridge_invalid_ink_cartridge
hope this helps you.
Oct 30, 2008 | Office Equipment & Supplies
Boating Logo
24 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Phil Walker
Phil Walker
Are you an Eagle Boating Expert? Answer questions, earn points and help others
