Question about Nokia E90 Cell Phone (Unlocked) - Black
Front display stays dark after boot sequence
After changing my covers, i can switch on my e90 without problems on the front switch, keyboard backlight is on, NOKIA is shown on the front display, then lights and display is off, only the inner display shows all information. Closing the cover, the out display never comes back.
IMHO there must be a sensor indicating, if the cover is closed or not, which makes the S60 OS switching displays and resolution.
Urgent help needed!
thanks in advance!
Martin
  • 205 Answers
You must forget to re install the magnetic piece which located in the lower left corner of the lcd frame cover try to check it
Posted on Apr 21, 2010
My wife's presario cq60 widescreen laptop has a power problem. For a period of time now, several weeks, on occasion it will simply go dark and nothing lights up. I remove the battery and power cord...
By go dark do you mean it turns off? If not, LED lights on the front of the laptop continue to stay on, but the screen goes dark, this could mean the backlight of the screen is going bad. It might be intermittent, but, a screen consists of two elements, the display itself, and the backlight which is what makes the image bright. If you bring it into a well lit area when it is dark and tilt the screen back and forth, you might see the faint image on the screen. Sadly, screen repairs are expensive, easily exceeding $300 most of the time. It is often a better idea to replace it rather than repair it.
Aug 24, 2011 | Compaq Presario CQ60-220US PC Laptop
After working normally for several years, my Inspiron 1100 display went dark but will come on normally if I press Fn+CRT/LCD BUT ONLY FOR 1 OR 2 SECONDS then goes dark again. Tried holding F8 during...
there is a ribbon cable going from the lower [keyboard unit] to the upper unit [display] that has been going bad over time. or the display panel backlight is bad.. you might be able to save old betsy by taking her to a laptop shop and see what they can do..goodday
Nov 09, 2009 | Dell Inspiron 1100 Notebook
I spilled juice on my gateway T-6330U laptop keyboard. I shut if off and pulled the power cord. I noticed it trying to boot up when cleaning it off, the LCD was fadding, and I heard sizzling under the...
Check the video connectors on the motherboard.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 21, 2009 | Gateway T-6330U Notebook
Blank display
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 23, 2009 | Toshiba Satellite M35X-S161 Notebook
When booting screen goes on for a second and blank after that
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 11, 2009 | Fujitsu Computers & Internet
NO DISPLAY ON TOSHIBA M35X-S149 LAPTOP
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Apr 29, 2009 | Toshiba Satellite M35X-S149 Notebook
Dark display
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 11, 2009 | Computers & Internet
Ibm t20 no LCD backlight
while the T20 is on and manifesting the dim display....
1. try to slowly close the lid (but not totally closing it) and then pulling it back to its original position slowly. Tell me if the light goes back.
if by doing that action the backlight lights up, you are most likely faced with a Flex cable problem. You might need to buy this from ebay. (dim display problem in T20 series is very common these days due to wear and tear of the flex cable)
2. Also try to use a pen to turn on and off the limit switch that triggers the backlight. This is located above the keyboard below the lcd. See what happens.
Apr 10, 2008 | IBM ThinkPad T20 2647 Notebook
Motorola RAZR V3 - Backlight
Try removing the battery for a few seconds then restart the phone. Other than that, it could be a defective switch on the phone that detects when it's closed. If it answers / hangsup when the opened or closed... the switch is good.
Geno
Mar 04, 2008 | Motorola Mobility RAZR V3
Nokia E90 Cell Phone (Unlocked) - Black Logo
793 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
