Unable to reach min washing temp of 150 and rinsing temp of 180 on a model Jackson/Alco model B24
Comments:
Jun 19, 2009
- Thanks for your solution. I was wondering if you have a picture or describe the location of the Thermostat
Jun 24, 2009
- Thanks I replaced the thermostats for washer and rinse, Unfortunately, I will need to replace the rinse thermometer, since it only goes up to 140( looks like a real doozy). I am able now to reach 168 degrees on the washer thermometer, but I have a question ? I was given a heat patch from the Health inspector and I stuck it on a plate and ran a manual mode for awhile to reach 168 degrees. Now the patch is turning black on 160 and grey on the 170, but not the 180 needed for rinse. Is there a rinse mode on this model, there seems to be no dial or switch for it? Not sure of operation maybe.
A domestic dishwasher is provided with a control system having circuitry including timer switch means adapted to insure automatic wash water at a normal set temperature for all cycles with the user having an option to preselect an elevated wash water temperature. During wash periods, power for the heater is provided through timer switch means connected through a first thermostat whereby if the water in the chamber is below its set temperature, the first thermostat will energize a heater to provide auxiliary heat to the wash water. The timer switch means is operative to stop the timer motor until the water is heated to said set temperature. Once the water reaches the minimum set temperature, or if the water supply is initially above said minimum setting the first thermostat will switch, deenergizing the heater. If an extra hot wash option is selected by an Options Selector Switch, and the water temperature is below a second thermostat's elevated set point, the timer switch means will stop the timer motor providing extended heating until the second thermostat closes upon the water reaching the elevated temperature.
The thermostat can be found from underneath the dishwasher, most models have them mounted on the bottom of the tank. Some are screwed in and some models are clipped in,
Your on the right track with the thermostat being the problem.
it is 13 no and 14 no contacts, and A1, A2 an others contacts. which one i supposed to connect the...
(More)
it is 13 no and 14 no contacts, and A1, A2 an others contacts. which one i supposed to connect the control wires?
i have the new Jackson avanti commercial dishwasher for my child care center. i need the...
(More)
i have the new Jackson avanti commercial dishwasher for my child care center. i need the commercial detergent that attaches to the washer with a hose and dispenses automaticallly. what is the name of the detergent and where can i get it
We have jp-24B series dishwasher it was doing great until about 2 months ago and the glasses come...
(More)
We have jp-24B series dishwasher it was doing great until about 2 months ago and the glasses come out all spotty. The dishwasher seems to be running through all the cycles and it gets up to temperature but the glasses have all thses lines when the water drains out of the glasses and spots, a light chaulky color. We have ran the dishes for 2 or 3 cycles and it helps a little bit. What is the problem?
