Question about Fuji FinePix Cameras
Pictures have concentric rings on them - FinePix Fuji Cameras
Incoming call is delayed from ringing 7-15 seconds
First you will have to explain what transmission network is being used, maybe the delay could be on that. What cards are you using to provides the voice circuits?
Regards
Len
Oct 24, 2012 | Alcatel Newbridge MainStreet 3624...
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
Fax wont send or receive? I can here it ringing though wont send???
Try changing the cable from the phone wall outlet to the fax, when a incoming RING signal comes, with a bad phone cable (it is 90 volts AC) so the power to ring the fax can go through but not DATA, try pluging a standard phone in the wall outlet to see if it work's.... if the standard phone don't work than call the phone company's service desk, if the standard phone work's (initiating a call) than concentrate on the printer's trouble shooting guide...
Mar 14, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Finding area of a concentric circle
You find the area of the larger circle. Then find the area of the smaller circle. Then to get the area of the ring, you subtract the area of the smaller circle from the larger circle.
So basically:
Area of larger circle - Area of smaller circle = Area of ring
http://www.vitutor.com/geometry/plane/concentric_circles.html
pi. r2 = area 2pi. r=circumference of circle.
Read more: http://wiki.answers.com/Q/What_is_the_Formula_for_concentric_circle#ixzz1Cv8wAOJf
Jan 30, 2011 | Computers & Internet
My 1985 goldwing runs very rough with a load at 1800 to 2250 rpm. once I get it past 2600 rpm it seems to run fine. I have to reb it up at stops to get it not to miss and have the power to get me started....
Sounds like a restriction in the slow jets of your carburetors or improperly adjusted mixture screws. You might try a fuel additive like SeaFoam or Gumout. I prefer Yamaha Ring Free, available at Yamaha dealers. It is basically a concentrated version of Chevron's Techron Additive. The label lists two different concentrations you can use, basically cleaning or maintenance. Use the high concentration for a tank of gas, and be sure to change your oil afterward as the directions state.
If this does not clear out the problem, you will likely need to remove the carburetors to clean them.
Jul 22, 2010 | 1985 Honda GL 1200 Aspencade Gold Wing
Problem with my webcam device ''Micro Pack''
There is something known as focusing. I am sure you are aware of the phenomenon. Someone or you have inadvertently rotated the ring around the lens and changed the focus of the camera. So now all you have to do is to start the camera and sit in front of it and rotate the ring around the lens clockwise and anticlockwise till you get a perfect picture of yourself. Rotate the ring slowly so that you can concentrate on your picture's clarity and focusing.
Nov 18, 2009 | Computers & Internet
I have parker super o lube for o-ring lubrication silicone base. Please advise may i using this silicone oxygen cylinder O-rings.
No. Silicone is not approved for O2 use. Can ignite under high O2
concentration/pressure. If approved for O2 use, the MDSS or labeling on the package will indicate so.
Oct 23, 2009 | Oxygen Lubrication Technology Christo-Lube...
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
Jan 14, 2007 | Sony KV-27V55 27" TV
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
Cameras Logo
15 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
