Question about Empire DV-35 Heater
IT WILL GO ON BUT WILL SHUT DOWN - Empire DV-35 Heater
Acer Aspire 7560 wont restart
Before shutting down your system click on any programs still running and shut them down. This will cut the time for normal shut down to take place.
You could also run a hard drive diagnostic to see if it has any errors. There might be some if you don't let the computer shut down itself. Restarting can also cause the programs to become corrupt, if they didn't shut down right. Running a defrag on the drive will also help it shut down quicker.
Look on the net also for information on getting your PC to shut down quicker.
Oct 18, 2014 | Acer Aspire Computers & Internet
Tip
Quick Tip: How to correctly shut your computer down
This may seem like a simple tip, it is, however it can cause many unneeded problems to your computer if you do not shut it down properly. Do Not shut down your computer by pressing the power button. Whether you have a PC or a laptop, don't use the button. When you go to shut your computer down go to start and shut down and it will shut off. If you do not do this correctly it doesn;t give your computer the proper amount of time to shut down, you can corrupt your Windows files and eventually have problems even booting your computer up. Simple solution that will avoid future problems! Hope this helps!
Lori
on Oct 18, 2010 | Computers & Internet
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
Shut down automaticaly
Not much to go on, "shut down automaticaly" on battery or AC or both? A computer will shut down, or hibernate, if thats what you mean, that's a power setting? If a computer overheats it will shut down automaticaly to save the components from heat damage. If there is dust in the fan and vents it will shut down. If it is not getting sufficent air flow from vents on the bottom of the laptop through the vents on the side. One option is a Laptop Cooler.Is it shutting down when you are on it? When it's left unattended? Respod to this post for further assistance.
Nov 19, 2012 | Unknown Toshiba Satellite P755-s5385 15.6...
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
Dec 19, 2010 | Computers & Internet
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
E-machine computer will not shut down
When you say "it will not shut down", are you referring to clicking on start and then shut down?
You could try forcing a shut down by holding the power switch down for about 5 seconds.
Jan 18, 2009 | E-Machines eMachines Desktop PC
My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Dec 08, 2008 | Computers & Internet
Empire DV-35 Heater Logo
93 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
