Question about Boating
Wiring diagram 1994 malibu echelon ski boat
Wiring diagrams 1994 Malibu echelon
emissionwiz
  • 75822 Answers
SOURCE: no diagram for 3.1 chevy malibu
These instructions are for the 3.1 L engine with serpentine belt. To change the belt, you need to remove the engine mount first. But before you do that, you must support the engine so it won't tilt after you remove the engine mount bolts. You would also need at least one helper. Here's step by step: 1. Use a jack and a long enough wooden block to cover the oil pan. Larger block will distribute the forces better. Don't use only a jack or a small block, it might crack the oil pan. Note: normally, you shouldn't lift engine by the oil pan, you should use an engine hoist, but carefully support with wooden block works. 2. Slowly raise the jack to support the engine. 3. Unscrew (Counter Clock Wise) the 2 bolts and 2 nuts of the engine mount. It's on the passenger side right next to the serpentine belt. 4. Loosen the tensioner bolt, and remove the old belt. You may have to raise the engine a bit to get a big enough gap to slide the belt through. 5. Put in the new belt and route it according to the diagram, you may have to leave it off one of the pulley because the tensioner is so tight. Don't worry, you'll slide it on later. 6. Put tighten the tensioner back on. Make sure the round metal pin goes in the appropriate slot. 7. Here's the hard part, putting the belt entirely on the pulleys. You have to either: a) Put a 3/8" ratchet in to the slot near the tension pulley that says "LIFT" and pull really hard to compress the spring, while putting the belt on the one of the pulley. Unless you are Arnold, you will need help. b) Pull a rope behind the tension pulley arm and pull while pushing with your left arm on the pulley arm to compress the spring; then get another person to hook the belt on one of the pulleys. 8. Put the engine mount back on. 9. Test run the engine to make sure you didn't mess up. Turn on accessories like A/C. If the temperature goes way up, you messed up. The water pump might be spinning the wrong way. Note: If you don't have a good floor jack, you can jack up the car, place a support under the oil pan, then slowly lower the car until the engine is supported. In this case, jack-stands or blocks under the frame are a good idea to avoid lowering too far
PLEASE RATE THIS SOLUTION WAS ALLOT OFWORK TO FIND IT.
Posted on Dec 10, 2008
  • 146 Answers
SOURCE: wiring diagram for a kenwood KDC MP232
Aftermarket cd players are all universal and have the same colors. You need to go to your local car audio store such as walmart, bestbuy, ect and buy a wire harness adapter. Then all the wires are color coordinated to make it easy, just wire colored wires together and plug in. If I have helped please leave positive feedback. Thanks
Posted on Jun 08, 2009
gemmy23
  • 346 Answers
SOURCE: I need a diagram on the car wiring for the radio
Maybe this will help.....
1999 Chevrolet Malibu Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Posted on Jul 11, 2009
  • 244 Answers
SOURCE: need a serpentine belt routing diagram for 2001
it doesn't show you under the hood near the hood latch ,newer vehicle it should. check this first.
Posted on Apr 23, 2010
clifford224
  • 1975 Answers
SOURCE: 2001 chevy malibu 3.1 liter
Here you go. I hope this picture helps and good luck.
Posted on Apr 12, 2011
1995 Cajun bass boat. Where can I get a wiring diagram?
cajun manual and parts manufactures
www.bbcboards.net > BBC Boards > Bass Boat Forums > Cajun Boats
Jul 18, 2011 - 13 posts - ‎11 authors
... for cajun boats and also a complete manual in pdf format and wiring schematics. ...bassmannbama is offline ... a wiring diagram too because switches arent working andmy wiring ... My email is : steve1995z@hotmail.com.
Cajun Boats Owner's Manual 1992+ available on pdf
Apr 19, 2012 - 4 posts - ‎4 authors
I scanned in my owner's manual and have it available if anyone is ... Mine is a '95 1950 Fish n Ski, but I believe it would cover bass boats as well. ... Looks like I'll need to learn about electrical and general boat repair.
Nov 19, 2015 | Boating
I need the wiring diagram for a 2001 Chevy malibu and the vacumm hoes diagrams also
Visit the autozone.com website and register the car. It doesn't cost anything and will give you access to an online repair manual for the car. The wiring and vacuum diagrams should be available there. Hope this helped and best wishes.
Sep 07, 2009 | 2001 Chevrolet Malibu
Wiring diagram for the ignition wiring harness for a 99 Malibu?
you can go to a chevy dealer and get a diagram of the wiring, or go to any auto parts store and buy a haynes manual for your car. the wiring diagrams are in this manual. for about $20.00,
Aug 27, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
2001 chevy malibu wiring diagram
what our problem maybe i can help you they run plus or minus 46 i change lot of pump let me no
Aug 02, 2008 | 2001 Chevrolet Malibu
Boating Logo
78 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
