Question about Brother DCP-8040 Copier
Paper Jam error came up, paper was removed but Paper Jam Error and red light still showing
  • 13 Answers
SOURCE: How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Posted on Nov 30, 2007
JohnSc
  • 21 Answers
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Posted on Feb 11, 2008
SOURCE: Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Posted on Nov 14, 2008
  • 1738 Answers
SOURCE: error paper jam light still flashing after jammed
Unpluging the printer for ten to fifteen minutes after removing the paper jam. This will clear all the memory in the printer and the error codes. If the error code still pops up contact the manufactor.
Posted on Aug 12, 2009
Testimonial: "Thank you"
  • 28 Answers
SOURCE: Red error light is flashing on Brother HL-2040
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_006.html?reg=us&c=us&lang=en&prod=hl5240_all
Hope that helps,
Tiger720
Posted on Sep 13, 2009
Continual paper jam error on Epson XP-412
There may be shreds of paper stuck deep inside the printer. Sometimes it takes a bright light such as a flashlight to locate them for removal.
Oct 30, 2014 | Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Flashing red light error, switching on and off doesn't help; no paper jam
Red light error shows the paper jammed or the no toner
so plz replace the toner of the printer
Apr 30, 2010 | Office Equipment & Supplies
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper jam
well part inside your product (paper handler/sensor) got damaged. must be serviced / non-user serviceable part.
Jan 22, 2008 | Epson 1000 ICS All-In-One InkJet Printer
Error LED blinking after paper jam, won't print
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
Dec 13, 2007 | OKI B4100 Laser Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Brother DCP-8040 Copier Logo
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
