Maytag commercial automtic washer displaying an F1 error code. What is F1?
  • 2 more comments
  • monica_barna Jun 18, 2009
    Maytag Model # MAH22PRAWWO Type: 493
    Thanks so much for your help Rylee. It is greatly appreciated. I will do as suggested to see if it resolves the problem.
    Thanks despentiado. Will check as advised and see if it resolves problem.
  • Joe Povoas May 11, 2010
    complete model# please
Hi
I am using the Commercial washer in my apartment.
but it has just color, white delicate , brights, perm press, woolens, delicate
Some of my clothes need to be washed by cold water.
How can I control the temperature of water?
or
what is the temperature each section?
Thank you for reading
Posted on May 18, 2010
  • 111 Answers
CUSTOMER CONCERN: Customer has F1 Error Code. The control is sensing an error in the signal from the air pressure sensor circuit. CAUSE: CORRECTION:
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed. A) Air leaks in the air pressure (switch/sensor) hose. a. Inspect the hose for cracks, pin-holes or loose connection. b. Replace the hose and harness assembly if it is compromised. B) Moisture in the air pressure (switch/sensor) hose. a. Inspect the hose for evidence of water. b. Replace the hose and harness assembly if water is detected. C) Lint or flashing in the air dome hose connection port. a. Inspect the air dome hose connection port for lint or flashing. b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub. D) The control needs to be replaced. a. Replace the control only after you have completed steps A – C above, and verified that there are no issues with the air pressure system.
Posted on Jun 18, 2009
  • Joe Povoas Jun 18, 2009
    MAH22PRAWWO its a washing machine not a range
    Brigadier General:
  • 8,619 Answers
Hi!
F1 error code means a defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Thanks for using FixYa.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
What fauit code f26 mean
This error code indicates that the door needs to be opened and closed.
For a more thorough explanation, check out member Yadayada's explanation here -
My maytag commercial washer display code F26
Sep 20, 2017 | Washing Machines
How do I reset/clear error codes F20 and F21 on my Maytag commercial washers?
Try to turn off power for 2 minutes and fool the washer into thinking it is new vs suffering a water loss. If that doesn't work see if there is a reset button on the mother board.
May 16, 2016 | Maytag Washing Machines
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    My maytag commercial washer display a code F26
    The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
    The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
    If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
    If Pause/Off or Pause/Cancel does not work:
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, and the condition above has been checked, call for service.
    Oct 23, 2012 | Washing Machines
    F1 error code
    Call Whirlpool at 800-688-9900.
    Let them know you have a Bravos or Oasis washer and you are getting a F1 error code.
    They will send someone out to replace the controller board for free!
    If not, here is a link to the control board you need.
    Oct 16, 2012 | Maytag Bravos Top Load Washer
    Maytag Bravos error code f1
    F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
    Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
    My Maytag Bravo washer starts, then stops and displays a F1 code. I turn it off and restart it several times before getting beyond this. What's the solution?
    The solution is easy. Remove the screws in the back and find the pressure tubing from tub to the control. Remove it and blow through that tubing to get the sand and sediment out of their. Re attach the tubing and retry. I have more:
    F-1 Error Solution
    Bravos Washer Error Codes
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Feb 03, 2011 | Maytag Washing Machines
    The f1 code on the Maytag Bravos top loading washer keeps going off and stopping the machine
    Please contact Maytag to inquire about the code F1. They should check the system and that that code is a courtesy repair and should be scheduled for a someone to come out to fix it. FREE
    It is possible that the F1 code was caused by your laundry habits (detergent), but I think that is unlikely. Too many of these machines have problems with the F1 error code. There is a known problem with the Oasis / Cabrio / Bravos machines.
    Aug 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
    Washing Machines Logo
    486 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
