Question about Microwave Ovens
SMV 360 ual - Microwave Ovens
What does E-26 mean
It must be brand specific and you don't give make and model. The only E26 error code that I can find is for an Xbox 360!
Jul 06, 2016 | Microwave Ovens
Sharp microwave instructions
Have you tried going to the Sharp website?
Jul 15, 2014 | Microwave Ovens
Safe to use a microwave that is making a loud rattling sound?
It's not a good idea to continue to use it when it's making an unusual noise.
It may be arcing, which can lead to further failure or a fire, or it may be a defective stirrer or fan ,which can lead to uneven cooking or further failure.
$360 for a service call? Are you in Alaska or on Mars? That's insane. Maybe you can contact another servicer in your area?
Jun 09, 2013 | KitchenAid KHMS145KSS Microwave Oven
Safe to Use with Loud Rattling Sound?
I HAVE LOST MY POLDER THM-360 MANUAL. I CAN'T SEEM TO CHANGE THE TEMPERATURE. I PUSH THE +/- AND IT DOES NOT CHANGE. WHAT AM I DOING WRONG?
here's link to POLDER THM-360 MANUAL online.
http://polder.com.p2.hostingprod.com/images/instructions/THM-360_instructions.pdf
Nov 23, 2010 | Microwave Ovens
Samsung SMV blower installation
Most Microwaves arrive ready to vent back into the room. For filtered air returned to the room it should face toward the front. For top vent, point to the top. for rear wall vent point toward the back.
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave vent fan replacement
(I'm assuming you're talking about the hood / vent / exhaust fan instead of the internal magnetron cooling fan).
The part # SMV-260UA-C will not be enough to go on, as there at least 3 variations on that number shown at Samsung parts.
These microwaves are made by Samsung, but you'd need the GE part number to replace the whole thing. They don't sell the blades separately.
The part # for the "ventilation motor" is WB26X10042 and you can find it for $97.11 here, which is about fifty dollars less than direct from GE.
I may have available a replacement flan blade off a used unit. If you'll send me the dimensions, I'll check. I need the length of the fan blade, the diameter, and the inside diameter / shaft size, and whether the shaft is round or "D" shaped.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave vent fan replacement.
The part # SMV-260UA runs just under $60 from SamsungParts, depending on which of three versions you choose. You can find them here.
And a simple Google search shows quite a few hits for "SMV-260UA" and they seem to run about $40, assuming the listings aren't bogus - as so many search results are.
I have a few "new old stock" and used vent & cooling fans here.
I would be happy to supply one whole or just the blades if you like.
Just tell me the dimensions: diameter of the shaft hole and the length and diameter of the "squirrel cage" itself and I'll see if one of mine would work.
Jul 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
First of all, if it's just the plastic (nylon) fan blade that's melted, most any fan blade should work. I'd take the blade and motor to a local appliance parts shop and see if they have just a blade assembly that would fit. Normally the shaft diameter is standard and the only consideration is to get a blade assy whose outside diameter and thickness are the same or a little less than the original. Concerning the original part # you gave there are 3 Samsung parts that match up on http://www.samsungparts.com : Part Number Description Specification Price DE31-10178A MOTOR-VENTILATION SMV-260UA,120V,60Hz,31 $67.78 DE31-10178B MOTOR-VENTILATION SMV-260UA-1,-,-,-,-,-, $70.09 DE31-10178E MOTOR VENTILATION SMV-260UA-N,-,-,120V60 $67.87 Lastly, if there happen to be any numbers on the blade assembly itself, you can check them to see if they're good numbers at http://www.samsungparts.com Good luck!
Dec 02, 2006 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
