Question about Pioneer VSX-819H-K A/V Receiver
Pioneer receiver makes loud hum after use - Pioneer VSX-819H-K A/V Receiver
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
Posted on May 17, 2009
  • 13 Answers
I had a similar problem when my Plazma TV + DVD Player + Receiver all interconnected. Some time later, I realized that the hum was leaking from CATV connecton to my TV antenna input which was indirectly reaching to my Pioneer receiver. When I disconnected the CATV cable, the sound was perfectly clean.
I guess mains power was interfering to CATV signal somewhere.
I.Kostak from Turkey.
Posted on Mar 20, 2010
I have an Aiwa PX-E77U turntable I'm connecting to a Pioneer VSX-454 receiver. The turntable has no ground wire. It plays okay at low levels, but as soon as I bump up the volume a little, I'm getting a...
It could be a bad connection of the earth pins to the cartridge. One turntable I had hummed even with an earth connection. I found out that the cause was the connection of the earth wire in a 3 pin plug.
Aug 31, 2013 | Aiwa Audio Players & Recorders
VSX 60 pioneer receiver shuts down on loud action dvd
Sounds like a bad speaker or speaker that is being over-driven.
Jan 09, 2013 | Pioneer Audio Players & Recorders
Can I connect my Dual turntable to pioneer VSX D712 receiver. I tried connecting it to a preamp (bought from Circuit City) and then to AUX, but all I get is a loud hum
I presume you bought a PHONO preamp from RS. That should be all you need. Is the TT otherwise functional? Loud hum is usually an ungrounded or unshielded signal cable. Phone cartridges create such a small primary signal that any external airborne electrical noise entering the circuit will be very large in comparison. Check cables and make sure the headshell is locked in correctly on the tonearm. Examine the small cables connecting the cartridge. Dual = good turntables. I have a CS1249 from the 70's.
Jan 09, 2010 | Pioneer VSX-D712 Receiver
May 17, 2009 | Pioneer Audio Players & Recorders
My pioneer a400 hums(very loud) through headphone sockets and speakers, why?
You're probably picking up 60hz AC hum. Through WHAT program sources? You need to isolate the source(s) before an answer can be given. Just phono or any other single source? Bad connection of the RCA cables or bad grounding. Try flipping the AC cord polarity around on the affected component.
May 04, 2009 | Pioneer Audio Players & Recorders
My record player works but makes an aweful noise like the turntable in rubbing up against somethin
If it is a loud hum besure there is a ground wire connected to the back of the receiver from the turntable.
Apr 24, 2009 | Audio Players & Recorders
Have a B&O RX-2 with mcc4 and loud hum
Possibly check the wires on the cartridge, make sure none of them are touching and are not bent to badly, are all the connections tight? some cartridges require plastic sleeves over the connections, this insure they don't touch and
avoids resistances between them. Also some cartridges are not compatible with certain model turn tables.Is it universal? Also you my need a mixer most turntables don't work with amps alone. Mine don't. Usually most models you attach the ground wire to the mixer. A mixer boosts table power and take stress off the amp. Hope this helped! good luck!
Jan 31, 2008 | Sony PS-LX350H Turntable
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
Pioneer VSX-819H-K A/V Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
