Question about Toys
The ancient train crept slowly up the Steep dangerous hill what are the nouns and that sentence
The ancient train crept slowly up The steep dangerous hill
canbruce75
  • 1776 Answers
SOURCE: when i hit the gas it takes a minute for the
If the check engine light is on, take the car to an autoparts store and have them scan the computer for any stored fault codes. Most parts stores will do the scan for free and getting the codes should help narrow down the cause of the problem. I would suspect a faulty throttle position sensor, but getting the codes should end the speculation. Hope this helped and best wishes.
Posted on Aug 02, 2009
  • 1986 Answers
SOURCE: parked on steep hill have to give a lot of gas
Are you driving an automatic? It sounds like the clutch plates inside your transmission may be slipping. Yes, automatics have small clutch plates between each gear whereas a standard has one big clutch plate
Posted on Aug 07, 2009
SOURCE: I have a John Deere LA150 that will not go steep
I have the same problem same year, same model. I changed the drive belt and it still won't go up steep hills that it used to easily climb. I don't see any way to adjust tension and it doesn't cover that in the operator's manual. What did you find out with yours?
Posted on May 24, 2010
ourhowse
  • 2007 Answers
SOURCE: car loses speed when climbing a steep hill.
Start with the fuel filter. Thats the most common thing. If no difference come back.
Posted on Jun 21, 2010
SOURCE: My 2000 honda crv loses power coming up a hill,
My car is doing the same thing.... I have found that the likely cause is the catalytic converter.....I just had my factory converter replaced when the clamp rusted out...about 5 months ago...I'm heading back to the garage to see what they can do about the replacement one failing.
Posted on Jul 26, 2010
Going up hill lack of power and smoke pulled over then started to go again didnt do it again on level ground what it might be
It will lack lots of power going up hill, especially if its a really steep one and you keep it in drive. Make sure you downshift to second, or fist if its really steep.
Feb 18, 2015 | 1995 Jeep Grand Cherokee
Is there a problem with 2006 hyundai accent starting when parked on a steep hill?
Have you changed fuel filter? Sounds as if debris is back lodging in filter when parked on steep angle. Just a simple suggestion
May 30, 2014 | 2006 Hyundai Sonata
1998 toyota hilux 3l diesel overheating when goin up long steep hills.
if its not going int o red zone it is normal to get hotter as she climbs hills
Oct 15, 2012 | Cars & Trucks
Brand new less than 30min on tractor when mowing down hill white smoke bellows out the exaust I imediatly shut mower down and am parinoid about restarting for fear of damaging motor.
how steep of a hill was it?steep enough for oil to go forward into the from of the engine roll it to a flat surface and check the oil level if ok run the engine and let it burn off if the hill ii's that steep then stop using it on the hill check the manual for running angles
Jul 10, 2012 | Craftsman GT 5000 26 HP54" Garden Tractor...
On a 2010 Ford Escape, what does a car on a slant symbol mean?? Thanks
this button is for steep inclines up and down to help slow car down on steep hills and help climb steep hills
Dec 02, 2010 | Ford Escape Cars & Trucks
I have a broken spoke on the back wheel of my bike, and the wheel wobbles from side to side. Is it dangerous to ride up a steep hill, I need to get home, and am wondering if it would be best to walk it or...
This depends mostly on your weight. Yes, it's safer to walk, but if you are a small person, and you can ride the bike on a level surface (like a parking lot) without the wobble increasing, then try pedaling hard in the parking lot. If that works ok, then you can probably get by. Don't ride fast. Don't ride down a steep hill. If you have hand brakes, and your front brakes are good, then don't use the rear brakes. But don't go over the handle-bars by using the front brakes hard! If you are not a small person, then walk the bike. Good luck.
Aug 09, 2010 | Cycling
While maintaining speed at around 2,000 rpm the motor seems to cut power to the transmission and I slowly lose rpm till it picks back up and then sputters so on and so on... have replaced plugs, fuel...
check your 02 sensors,also sometimes that could be from clogged cat.converters,usually from bad gas, i had the same problem,but lucky for me, i went up a steep hill,i forced it and i heard a loud pop,black smoke,then i got my power back,but ive been told that could be dangerous as you can destroy ur engine from back flow,good luck
Aug 06, 2010 | 1994 Honda Civic
It just stoped running
Depending on how much gas was in the tank and how steep the hill was, the fuel pump most likely started pumping air instead of gas, thereby stalling the engine.
May 10, 2009 | 2003 Ford Ranger Regular Cab
2005 Mercedes E320 automatic rolls back when on a steep hill .
you are loosing pressure. you can probably replace the circuit board inside the transmissio or it's the beggining of needing a transmission.
sorry.
Dec 28, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Hesitation
shift your gear to the left one tap to go into drive 1 when climbing steep hills and it keeps you from hesitating .it works for me i have a 2009 caliber automatic and i climb alot of kentucky hills ,mine only hesitates on the really steep hills after i slow down and take off again but when i shift to d1 its fine
Jul 23, 2008 | 2009 Dodge Caliber
Open Questions:
Toys Logo
24 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
