Question about Paul Mitchell Flat Iron 1-3/8"
Need a circuit board - Paul Mitchell Flat Iron 1-3/8"
I need the circuit board for a Rowenta steam iron Model DW2070
I tried to take apart a rowenta for my neighbor-Basically it is GLUED TOGETHER and is basically non repairable unless returned to vendor who repairs tge ho get them reglued! Weird!!!!!
May 23, 2014 | Rowenta DZ9080 Iron with Auto Shut-off
I need parts for my futura ce 250 and can not find anywhere to purchase them except for bobbin cases sewing ft i need more internal parts
http://www.sewingpartsonline.com/singer-ce-250-sewing-machine-parts.aspx has some of the Futura parts (belt, bobbin case, hook and circuit board, among others).
Which parts do you need?
(note: some parts are common to other machines. Those parts are the most likely to still be available online.)
Oct 02, 2013 | Irons
Short in wire - turns on but then shuts off with movement- then on again
THIS HAPPENS WHEN THERE IS A SHORT CIRCUIT OR THE POWER CORD IS DAMAGED.A REPLACEMENT WILL SOLVE THE PROBLEM.
Regards.
DON'T FORGET TO RATE MY SUGGESTION
Jul 06, 2011 | Black & Decker D2030 Iron
I have an older (1997) Rowenta DE 11 Powerglide iron. In the process of cleaning it, I mixed up the order of the wires. The colors are brown with the power cord, dark blue with the power cord, blue by...
If you can take a sharp picture of the circuit board and send it jodamechanical@aol.com I might be able to help you.
P.S. Make sure all wires and circuit board are clear.
Feb 10, 2011 | Rowenta Powerglide DE011 Iron with Auto...
Steam stop
I had the same problem i resolved it replacing the electronic board near the on/off button
May 16, 2010 | Rowenta DG-920 Iron
Need the circuit board for a DE-871A Iron / Iron does not turn on
The electronic shutoff light blinks but won't stay on, so the iron won't get hot. Can this be repaired? Can I disable it?
Dec 14, 2009 | Rowenta Professional DE871 Iron
Iron won't turn on,no lights or steam?
circuit board has shorted out that control iron functions
Aug 10, 2009 | Euro-Pro Shark GI490 Iron
Beeping and error message
Your Iron has a faulty circuit board and need to be replaced
Jul 23, 2009 | Black & Decker D2030 Iron
Got extremely hot and won't heat now
circuit board or power cord failure
May 16, 2009 | Euro-Pro Shark GI490 Iron
Paul Mitchell Flat Iron 1-3/8" Logo
Top Paul Mitchell Irons Experts
Are you a Paul Mitchell Iron Expert? Answer questions, earn points and help others
