Question about Echo Garden
Cs 310 clutch cap nuts
I bought a nes CS 310 and when I started to loosten the clutch cap nuts (also holds the bar) I noticed they were VERY tight, possibly over torqued at the factory. When the nut was reversed the stud seemed to turn with the nut. I took it to the dealer and they were able to successfully remove the nuts. I've replaced chains on other saws and NEVER thought the stud was turning when reversing the retaining nuts. Has abyone else experienced this with a CS310?
steve_lima
  • 181 Answers
SOURCE: Chain becomes very loose with little use
the problem with torqueing the nuts is that it's not enough tighting.i tell my customers that you need to tighten them as tight as you can get them.the nuts will not vibrate loose then.don't worry about breaking the studs they are very hard.
Posted on Feb 24, 2009
SOURCE: echo chainsaw clutch cs 370
the nut is part of the clutch bell housing just spin the bell counter clockwise and hold the flywheel or you can buy a tool that goes in spark plug hole its called a "dead stop"
Posted on Jun 22, 2009
Dolfoff
  • 148 Answers
SOURCE: How would I replace the bar hold down stud bolt in
At our dealership we replace the Bar studs with Heli-Coil and locktite for $20.
NOTE: Remove the old stud by double-nutting and screwing out of the case and marking the end that came out. Take it with you to NAPA and get the correct Heli-Coil size and a small tube of BLUE Loctite. (Might be cheaper to let the Stihl dealer do it)
Hope this helps!
Posted on Sep 28, 2009
dontbother10
  • 2220 Answers
SOURCE: Need replacement crankcase for Echo CS-750EVL chainsaw
There are 2 complete CS-750EVL saws on my local Craigslist.
Try here for Echo IPL:
http://www.echo-usa.com/pdf/documentation/CS750EVL_010185.pdf
If not your saw:
EchoUSA
http://www.echo-usa.com/documentation.asp
Type your model number into the search window.
Good Luck
Lou
http://seattle.craigslist.org/see/tls/1571477399.html
http://seattle.craigslist.org/tac/tls/1571683044.html
Posted on Jan 27, 2010
  • 252 Answers
SOURCE: after new clutch sprocket &good bar &chain
have you made sure that chain pitch and gauge are the same as the sprocket pitch pitches can be 3/8 lo pro 0.50 gauge
.325 x 0.50 gauge , .325 x 0.58 gauge
3/8 std x 0.50 or 3/8 x 0.58 gauge or 3/8 x 0.63 gauge
you could even have the correct drum but wrong rim sprocket on it
worst case is you could have mismatch bar and chain
make sure that bar adjjuster assy is working correctly
recheck chain / sprocket pitches and bar pitch and groove
gauge
be sure that you fitted chain to rim on sprocket correctly when you fitted bar and chain?
is the clutch cover pulling down tight ?
have a look and let me know if and what you find
cheers paul
Posted on Aug 12, 2010
Chain came off
loosten the 2 bar nuts do not remove completly the bar should move fairly freely slip chain back onto groove on bar pull bar to take out slack in chain snug bar nuts slightly there is a flathead screw behind the end of the bar next to motor tighten until chain is snug not too tight tighten bar nuts and your good to go you should be able to turn chain on bar by hand or your too tight
May 22, 2012 | Troy-Bilt Troy Bilt 18" Chainsaw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Echo cs-310....how to put chain on after it became lose....also how to tighen when it becomes loose.
At the right side take out the panel that hide the bolt that has a large groove.When unbolt move froward the chain holder and tight the bolt but not too tight just go further until you can test it by hand making the chain to move freely but stable.Reverse the procedure.
Post / thumbs / testimonial are welcome!
Nov 12, 2010 | Echo CS310 14" Bar Length Fully Assembled...
How to install bar and chain on cs 310 echo
A CS-310 OM follows:
http://www.echo-usa.com/pdf/documentation/CS310es1112_042310.pdf
There is a very good, model specific, procedure beginning on page 12.
There are 2 listed based on serial number I think, you can download the other and an IPL here:
EchoUSA
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 21, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
The chain on my Echo saw is moving very slowly to not at all
Your centrifugal clutch needs to be replaced or your chain guide (bar) is pinched.
Mar 14, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Need size of guide bar nut on model cs-330t
I went here, typed CS-330T in the search bar and found 6 IPLs. None of them list or display bar nuts. Odd!
EchoUSA
I suggest you take your saw into your local NAPA Auto Parts store. You might also contact Echo and suggest they add bar nuts to their IPLs for the benefit of the next guy. HTH
Lou
Feb 10, 2010 | Echo Garden
Echo chainsaw clutch cs 370
Jun 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Clutch cable
first need to set push rod freeplay 1/16th clearance @ engine clutch basket then set handle bar 41dee43.jpg
Mar 31, 2009 | 2004 Yamaha FZ6 Fazer
How do you replace the chain drive sprocket on an Echo CS-440?
you need to replace the clutch, you woould pull the side cover off and remove the bar and chain. then you remove the nut holing the clutch on( the clutch and sprocket should be on piece) take it to your local saw shop and grab a naw one.
Mar 18, 2009 | Garden
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Open Questions:
Garden Logo
127 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
