Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
Water dont pump up
The dish washer works on every cycle but wash is the pump bad
catriver
  • 878 Answers
SOURCE: Dishwasher Repair
Ebers, you have a seperate wash and drain motor on this model. When you remove the bottom panel the drain pump will be on the right and the circulation (wash) pump will be in the rear. You are going to have to verify that you have power getting to the wash motor. Sometimes this is difficult without removing the dishwasher. The motor may have a quick connect harness going to it that you can check voltage there. If you have voltage to the motor during the wash cycle and it's not running, well, there's the problem. If no voltage, then it's probably a timer issue. Catriver..post back
Posted on Feb 05, 2007
  • 351 Answers
SOURCE: dish washer won't wash
is the drain hose to low causing the dishwasher to fill and drain at the same time,if the water level is to low the motor wont wash the soap out of the dispenser.hope this helps
Posted on Mar 03, 2008
frcs68
  • 1605 Answers
SOURCE: Does not drain water after wash/rinse cycles
check the drain pump at the button of the dishwaher.
its not a big job, but it is a pain to take it out.
once you have it out, take a look of the bland on the motor, make sure they are all there, missing bland will cause the water to bunce back and nto drain completely. take a look of the motor, it should turn freely. the pump is oneway. make sure nothing else is broken from the pump and the outlet.
if all failed, replace the pump.
Posted on Oct 28, 2008
SOURCE: dish washer that does not pump out the water on it"s final cycle
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Posted on Feb 20, 2009
  • 97 Answers
SOURCE: I have a frigidaire quiet clean I.Water will flow.
the spray arm may be blocked see when door is open that it can spin and is any thing blocking the spray arm ,check if any food particles is in spray arm or tower check these areas out first write back if this dosnt work out.thanks
Posted on Dec 02, 2009
Siemens sn26m290
Could be that the pump is plugged or the water level switch is stuck. Check to see if the leveling switch moves freely by lifting it up and down a few times, then try the wash cycle again. Did you happen to wash dishes without rising them first, rice is bad for dish washers. Rice gets plugged in the diaphragm which is located in the drain line. You may have to remove the drain line fitting and clear debris which is lodged in the fitting.
May 11, 2013 | Dishwashers
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
My Frigidare Affinity front load washer doesn't pump water on the Normal cycle.
Check the water inlet electro valve at the rear of the washer and make sure it is working.
Jul 25, 2017 | Frigidaire Washing Machines
Du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Nov 01, 2009 | Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
12 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
