Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
    Problem Solver:
  • 18 Answers
Here are a few tips to look at, I would first check your inline fuel filter to make sure its not clogged up. See Page 26 of the Manual for additional help.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_NAen/HUSO2010_NAen_YTH2348_532441716.pdf
PROBLEM
Will not start
CAUSE CORRECTION
1. Out of fuel. 1. Fill fuel tank.
2. Engine not "CHOKED" properly. 2. See "TO START ENGINE" in Operation section.
3. Engine flooded. 3. Wait several minutes before attempting to start.
4. Bad spark plug. 4. Replace spark plug.
5. Dirty air filter. 5. Clean/replace air filter.
6. Dirty fuel filter. 6. Replace fuel filter.
7. Water in fuel. 7. Empty fuel tank and carburetor, refill tank with fresh gasoline and replace fuel filter.
8. Loose or damaged wiring. 8. Check all wiring.
9. Carburetor out of adjustment. 9. See "To Adjust Carburetor" in Service Adjustments
section.
10. Engine valves out of adjustment. 10. Contact an authorized service center/department.
Posted on Jul 02, 2014
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
Posted on Sep 04, 2010
  • 3 Answers
SOURCE: i need a drive belt dagram for a husqvarna yth2348 hydrostatic
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
http://www.husqvarna.com/us/support/download-manuals/?query=yth2348&types=I&brands=
Posted on Apr 20, 2012
No fuel flow from tank to engine on Husqvarna YTH2348
Try changing the fuel line as there has been a few cases where the inter liner of the fuel line on the carb complaint systems collapsing causing this problem.
Also check fuel cap rubber seal if it has deteriorated and parts of it may be blocking fuel flow from the tank. An additional thing to try is leave the ful cap loose to if it is venting problem.
Jun 21, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna ridng mower springs under carburater broke,how to replace them
u have to take carb off get small needle noise pliers an put spring on govener firstthen on idle side of carb an put tighten carb down when u have it the spring on
Aug 23, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
If this is a briggs and stratton they have a fuel pump on the front of the carb and ethanol plays havoc with the diaphrams in the fuel pump. I have to overhaul the fuel pump each year. Before you try anything else try "mechanic in a bottle" first. It is available at home depot, lowes, tractor supply etc. Just follow directions on the bottle and often it will clean out the varnish deposits in the pump and the carb both. Hope that helps.
Apr 15, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower cranks wont start prim carb and runs
check the solenoid on the bottom of the carb they stick and shut fuel off threw the carb
Apr 28, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower cuts off with blade engaged and backfiresafter it cuts off
check and or replace air--fuel filter if both good carb needs cleaning or repair
Apr 26, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna lawn tractor stop running has battery power and gas. Was using at when it stoped. Is it switch or senorid switch.
Does the engine turn over when you turn the key. If it does then it is mostly not getting fuel past the carb into the engine. If it does not turn over then it could be the switch or solenoid but it could also be a problem in your wiring system or a safety switch which is interrupting the ignition.
Sep 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
May 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
222 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
