How do i open drain outlet on my miele w1712 washing machine
ngfam1
  • 639 Answers
SOURCE: how to clear outlet hose on miele w 340 washing machine
THE OWNERS MANUAL USUALLY WILL TELL YOU IN MOST WASHERS !
Posted on Aug 26, 2008
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
  • 177 Answers
SOURCE: can't get filter out of miele washing machine.
this should just unscrew anti-clockwise. it is probably just tight
Posted on Aug 18, 2010
SOURCE: How do I fix a F53 fault ona Miele W1712 Washing
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
Posted on Oct 27, 2012
Does W1712 have an internal fuse? My machine has lost power despite the outlet being functional...
Hi dear,
Your machine does not have a replaceable fuse. If you are in AUS P/N:7790772 - Power-/Control unit EDPL 200-KD220-240Vse. I can advise to check part number with Miele, providing your machines serial number. I hope that helps. Thanks.
Feb 20, 2016 | Miele Washing Machines
Miele w1712 did not work...the machine was buzzer and when i saw it, it said waterproof fault
Hi dear,
There is a internal leak on your machine. You need to contact Miele to assist you. Thanks.
Jan 05, 2016 | Miele Washing Machines
I am looking for a new door seal for my Miele washing machine. its a brilliant machine but is leaking badly now. model W1712. your assistance in finding one for me would be very much appreciated.
Hi.
Miele make an excellent machine and I would advise you to have the door seal replaced by an experienced technician. The job is not as straightforward as it might appear.
I suggest you contact 2 or 3 repair people and check prices. Try to get some idea of the final price because the labour cost can be open ended and a big surprise...
I generally allow around an hour for a door seal replacement. It can take longer.
Good luck,
Nomess
Mar 03, 2015 | Miele Washing Machines
Miele W1712 honeycomb care front loader the door will not unlock after cycle has finished, it has been 24 hrs
Try unplugging the washer's electrical connection, wait for about 20 seconds then plug back in. See if that resets your cycle to Start mode from an unfinished mode. If not, see if you start another cycle, such as a spin to complete any draining of water. It might have blockage that is keeping the water from draining thus thinking the cycle is not over - or- a bad sensor not telling the computer that the cycle is over and it's OK to release the door lock.
Nov 24, 2014 | Washing Machines
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jan 04, 2011 | Washing Machines
Can't get filter out of miele washing machine.
Dec 29, 2008 | Miele Novotronic Premier 500 Front Load...
Waterproof fault
I just received this error message on my Miele WPS 4146 (Waterproof Fault) Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
So here is the fix that worked for me.
2. Unplug it
Jun 19, 2008 | Miele Washing Machines
Miele W1712 washing machine drain fault
Apr 05, 2008 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
