Question about Blenders
Nutribullet parts won't fit anymore
Parts won't fit anymore
Cup wont press down onto motor grips
Have you got something caught in it? Is it still under warranty? I am guessing but the mechanism inside the base should drop when you push to twist. Check is this is happening. If not then that may be the problem
Apr 21, 2015 | Magic Bullet Nutribullet Blender
Fax number for company called Nutribullet?
If they gave you a number, that is not a fax number, try to call it. Or try to locate their customer service department. Sending a fax about a problem with an order won't ensure that the proper people get the information to rectify the problem.
Also Try calling this number, and filling out the form on the NutriBullet website.
"Our customer service is available Monday through Sunday from 9am to 8pm, Eastern Time by phone at 1-855-346-8874."
https://www.nutribullet.com/customer-service.html
Feb 05, 2015 | Magic Bullet Nutribullet Blender
I bought a nutribullet less than a yr and it just stop working it does not smokeor smells like it burned.
ck where the cup goes onto the top make sure it turns on to lock on that is were the switch is to turn it on
Jan 20, 2015 | Magic Bullet Nutribullet Blender
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
How do I remove the nutribullet jar that is stuck to the blade housing?
strip the housing to release the blade, it is the only way to go.
Jun 30, 2014 | Magic Bullet Nutribullet Blender
How to open nutribullet jar stuck on blade base?
try heating the jar with hot water before removing it
Nutribullet manual
www.nutriliving.com/forums/were-listening/nutribullet-support
Jun 15, 2014 | Blenders
Magic bullet nutribullet is on base and does not want to start when I twist
There are 3 white plastic posts on the top inside of the power base. Push these downward to loosen it. Its full of sticky stuff because of overfilling. You can also put some oil on it. Buy parts from ebay and amazon seller amazingearth.
Mar 09, 2014 | Magic Bullet Nutribullet Blender
Blenders Logo
63 people viewed this question
Top Blenders Experts
Tom Chichester
Bill Boyd
Are you a Blender Expert? Answer questions, earn points and help others
