Question about ProMariner Pro Mariner Chrger Prom 5 Promite 5 On Board Charger 31305
Why do lights blink when charger is connected to 110 plug do the lights blink
When pluged in red lights blink
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
My headset doesnt turn on, when I plug the charger the red light starts blinking
Could be a combo of low battery and not yet being connected. Charge it overnight and check on it in the morning.
Check out the
Quickstart Guide
Mark
Motorola Support
Dec 31, 2014 | Motorola Mobility H270 Bluetooth Headset
The red light keeps blinking while I have the charger plugged in, is this normal?
Hi! If the light on the charger is blinking this can mean an issue with your charger adaptor. Check that the charger is still warm. If so, unplug the charger for a few minutes and plug it back in. If the light is still blinking your charger adaptor may need to be replaced. Hope this helps!
Sep 10, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
K850i red light turn on when charger or usb cable plug in & the phone does't start
I just bought a T303 Sony Ericsson I pluged it in to recharge it and a red light come on but no light come on the screen when Iunplug it from the charger.
Aug 22, 2013 | Sony Ericsson T303 Mobile Phone (Shadow...
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? lotsofstufflv@gmail.com
Jan 03, 2011 | Motorola Mobility H270 Bluetooth Headset
Laptop won't turn on
It may very well be a bad jack but it also could be a bad battery that is not retaining charge. Yes, a bad battery will cause many laptops not to turn on.
1- how does the charger jack fit; is it loose or wiggle when pluged in? or does it fit snugly with no movement when plugged in? If the charger no longer fits snuggly or moves a lot when plugged in, it may very well be a bad dc jack. Not a task for a DIYer but well worth having fixed.
2- Try removing the battery and see it powers on the charger only. Some laptops will not work without a battery and some will. If this is a Gateway, it probably will work without a battery.
Jan 08, 2009 | Gateway MX6448 Notebook
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
ProMariner Pro Mariner Chrger Prom 5 Promite 5 On Board Charger 31305 Logo
29 people viewed this question
Top ProMariner Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a ProMariner Cell Phone Expert? Answer questions, earn points and help others
