Question about Miller DS-25 Tripod
Miller DS-25 Tripod - Camera mounting plate - Miller DS-25 Tripod
Does the company that makes this tripod sell the small square part that screws into the camera?
Tripod quick mount plates (the part that is secured to the camera) are specific to tripod manufacturer. A tripod without a mating mounting plate is pretty much worthless as there is no way to mount the camera to it.
You will need to contact the manufacturer (or a reputable camera store) and provide the model of your tripod and the size of the threaded mount in you camera - most are either 1/4" or 3/8".
Apr 16, 2015 | Photography
What do I do to attach the camera after attaching it to the mount piece?
the quick release plate, that you are calling the "mount piece" will just snap onto the head of the tripod - if you aren't sure, a good way is to take off the QR plate from the camera, and then, with the screw threads face up, see how it fits into the head - many times, you have to engage the spring lever, so when you set the plate inside the head, it will snap locked into place. Then, re-mount it on your camera, and do the same thing, and there ya go.
Jul 01, 2014 | Manfrotto Camera Supports 3405BN JR. BLK...
Sunpak 5800d tripod quick release plate. What is the correct position to mount it on the camera and the tripod? Also what is the push button on the plate and how is it used? Thank you
Go to this site and look at the plate mounted onto the tripod, do it that way, so the bubble level is on your side, and the second little push button opposite of you. The second button is there for larger cameras, many video cameras mostly, that have two holes on the bottom, to keep them from swiveling side to side on the plate. Also, makes it easy to ensure you put it on right in the dark, the extra button should go toward the lens. :o)
Apr 12, 2011 | Sunpak 5800D Tripod
Having trouble mounting my Nikon D3000 to Zeikos 72" tripod. There is not manual included and I'm not sure how to get it to stay on the quick release plate, other than manually rotating the camera...
Quick release plates on all tripods are in two pieces. One stays on the tripod and provides a locking mechanism to secure the camera and the other stays connected to the tripod socket on the camera.
Jan 08, 2011 | Cameras
I have a SLIK Single Action Panhead Tripod. How do I mount the camera on the tripod?
it is a quick release plate. there is usually a button or lever to release the plate. you then screw the plate into the bottom of your camera or camcorder and mount the plate back onto the tripod. you can leave the plate on your camera when you store it to allow for faster setup.
Jun 03, 2010 | Slik AF-1100E Trigger Release Ball Head...
Where can I purchase the camera mount plate for
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
May 11, 2010 | Kalimar V-20S VIDEO TRIPOD
Old school IDEAL brand tripod called THE STABILIZER. no plate.
I picked up the same tripod without the mounting plate. Looked at several camera stores before I deceided to take some aluminum stock and make one.
Apr 02, 2010 | Kalimar V-20S VIDEO TRIPOD
Camera slips on tripod
Try cutting cork(available from local harfware store and gluing that to head. Be sure to cut precisely and don't forget about hole in center fot mounting post.
Jan 18, 2010 | Slik U-212DX Tripod
Unable to unscrew camera from mounting plate tripod
The mounting plate may have a small pin with a spring to fit certain kinds of cameras.
Don't try to twist the plate off the camera, that may damage the bottom of the camera.
Instead, the plate should have a slotted screw in the bottom that screws into the camera. Unscrew the bolt with a good screwdriver.
Hope that helps.
Jul 26, 2008 | Kodak EasyShare C875 Digital Camera
Miller DS-25 Tripod Logo
Top Miller Photography Experts
Tony
Are you a Miller Photography Expert? Answer questions, earn points and help others
