Question about Vehicle Parts & Accessories
I need power adaptor - Vehicle Parts & Accessories
    Sergeant:
  • 462 Answers
What for lol?
Posted on Sep 07, 2014
I'm traveling to India where electricity is 240. Do I need to buy a power converter for my Asus laptop?
most laptop power supplies support full range power input. meaning it will accept any normal outlet voltages used anywhere. if you look at the power supply of your laptop it should say vin (voltage in) 100v to 240v 50/60 hz, or close to that if it is.
Nov 01, 2016 | ASUS Computers & Internet
I have a model-JJB052000-2509 50/60 H2 Output5V-2000mA and I need power adaptor can you help me?
pls let me know where do u live,,you need 5volt 2 ampere adaptor,,u may use 2-5 ampere also,,volts should be =5 volts,,,u can charge ur note with laptop usb connector also,,,or u can find this adaptor on amazon.com,,,ali express,,,or any other as per ur area
Jan 27, 2015 | Archos 101 Internet Tablet 16GB 10.1"...
I have a Yamaha PSRE413. on/off does not work with adaptor, but works with batteries
If you are using the correct adaptor then the most likely reason is that the socket where the adaptor plugs in has broken away from the circuit board and will need to replaced/resoldered.
if you need a socket Google : Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
OR if you have used the wrong mains adaptor and the polarity was reversed you may have damaged the diodes / voltage regulator on the power input.
Jan 24, 2013 | Yamaha Music
No power. no lights. I have checked the power cord and its like there is no power
Firstly check that there is power to the Ac adaptor, this can be done by seeing if the green power indicator light is on on the adaptor body.
If not, then you have a defective plug, blown 3 amp fuse or the adaptor is fried (not uncommon)
If you have a multimeter, you can set it to 20 volts DC and with the adaptor pligged into the mains, test the DC JACK end! by putting the red probe to the inner part of the jack and the black to the outer part, if no reading, then assume the adaptor is dead.
Best way to check is by testing with an adaptor (universal charger type) to see if that works.
Assuming the adaptor is putting out power, check the output with a multimeter as above and see if the voltage is at the correct level (think its 19 volts on that model). If it is, then move on to the DC jack connection on the netbook
Watch the power indicator on the adaptor, if it is not steady green (ie flashes on and off), ther power is not making a circuit in the alptop and is being "spat back", this can be anything from a blown circuit board in the power circuit, to something as simple as a motherboard main fuse.
If there is a staedy green light but no power at the netbook and the jack connection at the netbook is firm and not sloppy or loose, then you will need to have the netbook dismantled and the fuse checked ( this will also need to happen if the jack connection is loose.
Sometimes, removing the battery, pressing the power button on (with the adapator unplugged) for 30 seconds and repowering with the ac adaptor can reboot the system, but I'd be inclined to suspect the adaptor first
Apr 22, 2011 | Acer Aspire One PC Notebook
Power adaptor?
If you need a replacement, you have two choices. Visioneer no longer makes this scanner, but they do offer replacement power adaptors. They run about $20 plus shipping. It may be quicker (and cheaper) to look on the scanner (maybe on the bottom or on the back, probably beside the power jack) or on the current adaptor itself and see what the power rating is. It will say something like "6 VDC, 1A" or "5.5 VDC, 3-5A". These are the two power ratings you need. VDC is the DC voltage, and A is the amperage. You can take the power adaptor to a local Radio Shack or similar electronics shop, and they'll help you with an appropriate adaptor. You may also be able to find an appropriate adaptor at a large electronics store (like Best Buy) or a large discount store like Wal-Mart or Target. Just go to the electronics section. A small speciality shop will probably take the adaptor and give you the choice of one or two that will work. In a larger store, you may not get as much help, so you just want to match both power numbers on the package, then make sure the plugs on the end of the power cords match, so the new one will fit your scanner (universal adaptors often include several tips that can be put on the end of the power cord; just make sure one of them is the same size and shape as yours).
Mar 06, 2011 | Visioneer OneTouch 5800 Flatbed Scanner
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
Laptop will not power up.
  • If possible, make sure there is power coming from the power adaptor with a voltmeter. If nothing shows, the adaptor needs replacing or repairing.
  • Try removing the battery and running on the power adaptor alone. If this works the battery is dead. You can buy a new battery or just run it on the adaptor.
Apr 08, 2010 | Gateway MX6450 Notebook
How to fix Power Adapter
Does your adaptor geting warmer when plugged to power outlet for some time (minutes)?
If not, than there are two possible solutions:
First (the easiest) thing is to check if both wires are not cut or short (one that you connect to power outlet, and the other one you connect to your laptop). You'll need some multimer to do this.
Most possible is that you'll need to open the power adaptor to do these checks.
Second thing is to locate and check the Fuse. Most of the adaptors have a Fuse inside.
If the fuse is OK, the wires are also OK, and the adaptor is getting warmer (or not), than you should buy a new power adaptor.
My experiance sais, not to belive much to repaired laptop adaptors (you don;t say what laptop you have).
Also, do not ask for substitute (cheap) adaptor!
Find an original one!
Most important is the following:
Please note that you should't try to do these checks, if you don't feel you are enough qualified. You should ask some friend of your's or some service. It should't cost you much !
Also, if you try to do this by yourself, be EXTREMELY carefull when adaptor is open. DO NOT PLUG it to power outled !!!
You might be killed !!!
Regards.
Mar 26, 2009 | Toshiba Satellite 2210CDT Notebook
Power Adaptor for 500GB LaCie P3 HD USB 2.0 7200RPM 8MB USA?
Both power adaptors are 4 pin, ITHINK that the Porsche that you have is the same as mine which has the smaller (4 pin DIN) plug 34W power supply.
But check on LaCie's site: http://www.lacie.com/asia/products/product.htm?pid=10857
Hope this helps.
Chris
Jul 23, 2008 | LaCie Computers & Internet
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
