Question about Razor MX500 Dirt Rocket
Battery is charged turn throttle nothing happens
What could be the problem if my son dirt bike says its fully chaged but when he turns the throttle nothing happens
Did the socket the charger was plugged into actually have 120vac in the socket?
Or are you sure the charger is actually working? Is there a short so that the battery is draining as fast or faster than the charger is providing a charge?
Mar 27, 2015 | Razor Dirt Rocket MX350 Miniature Electric...
MY RAZOR QUAD IS CHAREGED BUT WILL NOT RUN
I have exactly the same problem and it started right around the time the "gracious" 90-day warranty period expired.....
The battery lights had been on for days, indicating a full charge, but nothing happens when turning the throttle. Battery housing is very cumbersome to open, but I'll try to disconnect the battery next.
Jul 22, 2014 | Razor Dirt Quad Bike
CAN BATTERY DISCHARGE IN STEAD ON CHARGING I TURN IGITION AND NOTHING HAPPENS I CHECK STARTER AND BATTERY AT PART STORE
sometime but not all the time have the alternator check thats most likely problem.
Aug 09, 2012 | 2005 Ford Taurus
How will i know if its my batt or motor on off switch lites up red but nothing happens
Lift the rear wheel up off the ground and apply the throttle, while watching the throttle lights. If the throttle light goes from green to yellow or red it shows that the battery voltage is dropping under a light load because the batteries are low in capcity - not holding much charge. Most battery places will load test the batteries free of charge to confirm this.
Have a look at the trouble shooting guide here
http://www.razorama.com/razor-installation-guides.html
and the wiring diagram here
http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jul 30, 2012 | Razor MX350 DIRT ROCKET - BLUE
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
Bella scooter light says charged but nothing happens when turn throttle
check the batteries with a multimeteer and make sure they are putting out at least 24 volts
May 13, 2012 | Razor E200/300 Electric Scooter Battery
Push statrer button and nothing happens
Sounds like too much oil! Yeah it sounds like a switch. You can probably get that thing apart and see what's happening. Have you ridden in the rain lately or trailered it through heave rain? I trailered my Ducati through some heavy rain in North Carolina and washed all the grease out of the throttle, wouldn't even turn. I have a feeling, you have corroded the connection some how, check it out.
May 31, 2010 | 2002 Yamaha Road Star Midnight
Possible Alternator
have battery and charging system checked. you may have a bad starter.hope this helps.
Oct 14, 2009 | 1997 Buick LeSabre
Razor MX500 Dirt Rocket Logo
49 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
wayne-m
Are you a Razor Cycling Expert? Answer questions, earn points and help others
