Question about Paul Mitchell Flat Iron 1-3/8"
Need a new circuit board - Paul Mitchell Flat Iron 1-3/8"
I need the circuit board for a Rowenta steam iron Model DW2070
I tried to take apart a rowenta for my neighbor-Basically it is GLUED TOGETHER and is basically non repairable unless returned to vendor who repairs tge ho get them reglued! Weird!!!!!
May 23, 2014 | Rowenta DZ9080 Iron with Auto Shut-off
I need parts for my futura ce 250 and can not find anywhere to purchase them except for bobbin cases sewing ft i need more internal parts
http://www.sewingpartsonline.com/singer-ce-250-sewing-machine-parts.aspx has some of the Futura parts (belt, bobbin case, hook and circuit board, among others).
Which parts do you need?
(note: some parts are common to other machines. Those parts are the most likely to still be available online.)
Oct 02, 2013 | Irons
I have a Eurp-Pro 1000 ironing system. I need a new board cover and a manual
the instruc. manual download from www.fitness.manualsonline.com or www.retrevo.com
the parts go www.repairclinic.com or www.appliancepartspros.com
God bless you
Jul 18, 2012 | Irons
Was using iron with no problems when heard a pop and now wont work. Not the outlet. Is there a fuse that could blow, and is this something that is easily fixed? or is it better just to purchase a new...
Most likely it was the thermal overload, its a type of fuse, but could be a capacitor on the circuit board. The history of this iron's failures would lead me to tell you to get another on and not a Black and Decker. repair costs would be $25.00 and up just to get someone to look at it and parts for these are not widely available so any parts you get would cost extra for shipping. Wouldn't hurt to open it up and see if it is something simple but I would not pay to have it repaired!
You can only tell for sure by taking the unit apart and testing the circuit for continuity.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
A bad reading is almost assured with what your telling me .
Aug 23, 2011 | Black & Decker D6000 Iron
I have an older (1997) Rowenta DE 11 Powerglide iron. In the process of cleaning it, I mixed up the order of the wires. The colors are brown with the power cord, dark blue with the power cord, blue by...
If you can take a sharp picture of the circuit board and send it jodamechanical@aol.com I might be able to help you.
P.S. Make sure all wires and circuit board are clear.
Feb 10, 2011 | Rowenta Powerglide DE011 Iron with Auto...
Steam stop
I had the same problem i resolved it replacing the electronic board near the on/off button
May 16, 2010 | Rowenta DG-920 Iron
Need the circuit board for a DE-871A Iron / Iron does not turn on
The electronic shutoff light blinks but won't stay on, so the iron won't get hot. Can this be repaired? Can I disable it?
Dec 14, 2009 | Rowenta Professional DE871 Iron
Beeping and error message
Your Iron has a faulty circuit board and need to be replaced
Jul 23, 2009 | Black & Decker D2030 Iron
My singer magic press 4 iron comes on but the plate will not heat up. I turn it on one day and it just would not heat up.
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
Jun 18, 2009 | Singer CSP1 Iron
Paul Mitchell Flat Iron 1-3/8" Logo
Top Paul Mitchell Irons Experts
Are you a Paul Mitchell Iron Expert? Answer questions, earn points and help others
