Question about GE Monogram® ZBD6880NSS Stainless Steel Dishwasher
Ge monogram dishwasher door latch
Door won't latch
zeusfaber
  • 247 Answers
SOURCE: GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Posted on Apr 22, 2007
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Posted on Dec 28, 2007
  • 417 Answers
SOURCE: Door won't open
Call the store where you bought it or the GE repair service, you should be covered under warranty, this should not happen on a new machine.
Please remember to rate this solution.
Posted on Oct 22, 2008
  • 109 Answers
SOURCE: GE Dishwasher GSD2000 door latch/sensor malfunctioning
The latch could need a simple adjustment or may require replacing.
Is the catch (the part that sticks out of the dishwasher, not the door part) loose?
Maybe try to loosen it (dont unscrew it completely) and re-adjust it to suit.
Hope this helps!?
Posted on Jun 18, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Monogram dishwasher is leaking from the
Hi, Yes... Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
Ge monogram bottom oven won't clean
Follow the owner manual instructions, some condition is not set or the door switch or door lack it not operationg. Could be the monitor switch on the oven latch.
Mar 02, 2013 | Ovens
FRIGIDAIRE dishwasher door won't latch
Check to see if the door is not aligned correctly anymore, or if the door sags underneath the latch plate and go from there. You may need to adjust the door or replace the latch itself.
Jul 21, 2012 | Frigidaire Dishwashers
The door won't open - ran and re-ran the wash cycle, and it still won't disengage.
Switch OFF the main power and try. Give a bang by hand on the latch side. It might open. Do not use hammer etc.
If nothing works you have to force open carefully.
Sep 15, 2010 | GE Monogram® ZBD6880NSS Stainless Steel...
I have to replace the handle / latch assembly on a GE Monogram Dishwasher Model #ZBD6600G03SS. For the love of me I can't see how to do it. Do I have to get at it from inside, outside, both sides...
Hi
If the dishwasher door will not latch on your GE Monogram dishwasher and it is a new appliance, check that the door is not hitting screws or cabinets underneath the counter. For a new dishwasher, you might also need to push in the top of the control panel as you latch the door. The new gaskets might not have had time to seat properly. It may be necessary to run up to 10 dishwasher cycles for the heat from the washer to seat the gasket, which becomes more flexible after it is used a few times. For older Monogram dishwashers, check the loading rack to be sure no dishes are protruding beyond the back or front of the racks and that no dishes have fallen through to the lower rack. If dishes are dangling down into the lower rack, they could stop the lower rack from completely rolling into the dishwasher and could also stop the spray arm from rotating. Check that no silverware is obstructing the door.
http://www.acmehowto.com/howto/appliance/dishwasher/check/doorlatch.php
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Aug 03, 2010 | Dishwashers
Purchased a used Monogram Dishwasher/no factory info was included
First, here are some tips to help with your model number: look for an aluminum tag--or a silver or white adhesive label. The model number may be printed or stamped onto the tag and it may be written in two different type sizes or styles. You might find the tag in one of these places:
  • Inside the door jamb, to the left, right, or top
  • On the door, to the left, right or top
Feb 12, 2009 | GE 24 in. Monogram ZBD6880KSS Stainless...
GE Monogram ZBD0710 Dishwasher
THIS IS THE SOLUTION!
I was having the same problem with my Monogram dishwasher and oven.  Here's what to do.  You must fully remove the handle from the appliance.  Down the barrel of the standoff is a hex screw that, when tightened with an allen wrench, will draw the standoff tight to the handle again.  There is no need to remove the end caps.
Mar 27, 2008 | Dishwashers
GE Monogram® ZBD6880NSS Stainless Steel Dishwasher Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
