Question about Robin Subaru Electrical Supplies
Robins propane generator won't start
Generator was running fine than suddenly stooped and won't restart. oil and propane supply is fine
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Posted on Dec 05, 2008
  • 20 Answers
SOURCE: I have a Honda super
Check the oil. Many of these units have a safety switch that will shut off the unit if the oil is low. It doesn't take much on some of these. Or, just add a little oil and give it a try, it certainly won't hurt it.
Posted on Jul 09, 2011
southernburk
  • 23 Answers
SOURCE: i have an old makita g2700 generator with a robin ey25 engine.i need to change the oil.what grade of oil is recommended please
Hi Tim,
That engine's original production started out in 1987 by Teledyne and then taken over by Robin Subaru. Replacing your oil depends upon your climate, here's a list Below 14 degrees F 10w30 14-68 degrees F SAE #20 68-104 degrees F SAE #30A complete fill requires 28.7 OZ of oil according to the service manual.If the engine is burning a lot of, oil I would suggest that you jump up a rating on the oil. For example if you are in Florida and it's 95 degrees outside I would useSAE #40. If the engine is still within its tolerance and not consuming oil I would stick with the factory recommendations. On a further note,This is a fairly old generator and was designed to run on straight gas, NO ETHANOL!!!! Today's gas has at least 10% and it will wreak havoc on your fuel system. Ethanol will absorb water from the moisture in the air, It bonds with the water and sinks to the bottom of the tank. Gas with ethanol has a shelf life of about 30 days. Ethanol will also act as a solvent on the fuel line, creating a gum on the inside of the line and make the line very brittle. The gum will eventually migrate into the carburetor and foul it. I would strongly suggest that you replace the fuel line with Tygon or any other ethanol safe material, I would also swap out the fuel filter or add an inline one. Do not store the generator full of fuel, store it empty. Check out the website pure-gas.org to see if ethanol free gas is available in your area. It will last much longer especially with a little bit of Stabil in it. Good Luck,Michael Burke
Posted on Dec 02, 2011
Homelite LR5550 serges when it runs is there a way to set the governor so will run smooth
Try opening the high speed jet about 1/8 turn. If that don't work clean the carb.
Jul 07, 2014 | Garden
Guardian propane generator hard starting. At 20 F backfires and won`t start. Goes to overcrank.
It needs a cold weather option, one that heats the oil and also the carb so the LP gas does not freeze the carb. A common problem
Nov 04, 2013 | Guardian Electrical Supplies
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
Powermax xp8500e will start and run about 5mins quites restart and run about 5mins quites and won't restart (no fire at sparkplug)
most of this generators have a shut off for low oil, so check your oil level to see if this is the problem
Sep 15, 2011 | Watts Onan Portable Generator - 4000 ,...
I have a Honda super quiet 6300i generator. It runs fine and then suddenly will stop. It restarts fine and there are no warning lights of any kind lit on the generator. What could be the cause and how...
Jul 09, 2011 | Honda Electrical Supplies
No spark on Makita Generator G5501R
Atlas Machinery Supply Ltd.
233 Queen Street West
Toronto, Ontario, Canada
M5V 1Z4
(416) 598-3553
info@atlas-machinery.com
Apr 29, 2010 | Electronics - Others
Briggs and Stratton propane gernerator will not run.
The engine is starved for fuel. Check fuel flow. Possibly a dirty fuel filter someplace in the line or the regulator has low flow.
You can verify this by putting an UNLIGHTED Bernz propane torch into the intake. If that improves it, then low fuel flow is the culprit.
Fuel filters for propane are very fine and can plug up easily. I am not sure where yours are, however I would check at the inout of the regulator for one there for sure.
Mar 31, 2010 | Briggs & Stratton Automatic Home Standby...
Propane-converted generator sometimes sputters out and dies
I believe the problem may be with the propane. Have him call his propane provider and get them involved. good luck
Dec 26, 2008 | Coleman Powermate Premium Plus 6250W...
Have a 16k propane guardian generator have to manually start and
Rate me,
Carl
Nov 19, 2008 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
21 people viewed this question
Top Robin Subaru Electrical Supplies Experts
Steve
Gene Haynes
Are you a Robin Subaru Electrical Supply Expert? Answer questions, earn points and help others
