Question about Samsung Omnia Cell Phone
How to connect data on a gt b6520 - Samsung Omnia Cell Phone
How to enable mobile data of GT-B6520 Samsung
samsung if it is like my model
most likely at top of screen on home screen there is a hidden pull down menu. which will have mobile data tab. use finger drag it down from top of screen
Sep 15, 2016 | Samsung Cell Phones
I need unlock code for omnia pro 5
Hello. You can get the unlock code for a Samsung Omnia Pro 5 (B6520) from ProUnlocking.com at affordable cost with an easy unlocking guide. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Samsung B6520 Omnia PRO 5 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung B6520 Omnia PRO 5 is locked to.
CODE: Its the unique Unlock Code for your Samsung B6520 Omnia PRO 5.
Sep 13, 2014 | Cell Phones
How can i switch off data on my HTC phone ?
  • On most Android phones (ICS, JB, KK): go to Settings -> Data Usage -> Data Connection -> Slide the switch on off
  • On some HTC phone: use the Data Connection widget
  • On some Android phones (1.5 - 2.3): go to Settings -> Mobile Networks -> uncheck Data Connection
Other ways:
How to Turn Off and Disable Mobile Data Connection 2G GPRS Edge 3G on...
How to Disable Mobile Data Usage Beginners Guide
Enable or Disable Mobile Data Android 4
How to disable the internet connection on your smartphone turn off your...
Aug 25, 2014 | HTC Magic Cell Phone
Iphone stopped working
I don't have a lot of information to go on, but does this possibly help?
  1. Settings -> General -> VPN (should be not connected, if this is a personal device)
  2. Settings -> General -> Cellular -> Cellular Data (turn off, reset the device)
  3. After the device boot-up
  4. Settings -> General -> Cellular -> Cellular Data (turn on, reset the device)
IF that doesn't help (follow this )
  1. Settings -> General -> Reset -> Reset Network Settings (this will delete all Wi-Fi passwords)
  2. Settings -> General -> Safari -> Clear History -> Clear History
  3. Settings -> General -> Safari -> Clear Cookies and Data -> Clear Cookies and Data
  4. Settings -> General -> Safari -> Advanced -> Website Data -> Remove All Website Data -> Remove Now (** All data saved in Safari will be deleted)
  5. Reset the device
Aug 07, 2014 | Apple iPhone 3G
How can i start wi fi on my samsung B652o omnia PRO
Some time connections need extra verification code. i encountered this kind of situations many time on blackberry. Check the wifi connections menu.
Jun 11, 2014 | Samsung GT-B6520 OMNIA PRO 5 QUAD BAND...
How can i subscribed to packet data?
Packet data (EGPRS) Enhanced general packet radio service (EGPRS), packet data, is a network service ceive data over an Internet protocol which allows mobile phones to send and re (IP)-based network. It enables wireless access to data networks such as the Internet.77 . 2005 Nokia. All rights reserved © Copyright The applications that may use packet data are MMS, browsing sessions, Push to talk, e-mail, remote SyncML, Java application downloading, and the PC dial-up. Packet > Connectivity > Settings > Menu To define how to use the service, select Packet data connection > data . to set the packet data connection to be established when an When needed Select application needs it. The connection will be closed when the application is terminated. to set the phone to automatically connect to an packet data Always online Select network when it is switched on. indicates a packet data connection. Modem settings You can connect the phone using an IR or a data cable connection to a compatible PC, and use the phone as a modem to enable packet data connectivity from the PC. > Settings > Menu To define the settings for connections from the PC, select , activate Active access point > Packet data settings > Packet data > Connectivity Alias . Select Edit active access point the access point you want to use, and select , and enter a nick name for the currently selected access point. for access point , and enter the access point name (APN) to Packet data access point Select establish a connection to an EGPRS network. You can also set the dial-up service settings (access point name) on your PC using If you have set the 121 p. PC Suite the Nokia Modem Options software. See . settings both on the PC and on your phone, the PC settings are used.
Apr 14, 2011 | Nokia 6020 Cellular Phone
I need a packet data connection
Menu >> Tools/Settings>> Connectivity >> Connection Manager >> You will get the Packet Data Connection over there.
Sep 02, 2010 | Nokia 6300 Cellular Phone
Inernet settings for china mobile
hi...
do the following steps to set the airtel internet settings....
1)In Wap profile in setting for networksetup select a profile name it, home page :http://www.google.com gateway :100.001.200.099
port:8080 Data account :Airtel
In Data Setting :Put same name for profile as Data account : Airtel
Apn: airtelfun.com
Auth. type : normal
Data Setting And Wap Settings r connected together as part of Wap
or
2) Airtel Live
first click SERVICES icon in main menu==>DATA ACCOUNT==>GPRS==>EDIT any existing account==>
Account Name--> LIVE
APN-->airtelfun.com
Auth. Type-->Normal
save all the settings.
Come back to SERVICES==>WAP==>SETTINGS==>EDIT PROFILE==>EDIT any existing account==>
Rename Profile==> Airtel Live
Homepage==>http://live.airtelworld.com
data account==> LIVE (which we created previously)
Connection Type==>
Here u find three option
a) Connection-oriented
b) Connectionless
c) HTTP
choose c) HTTP==>
Proxy Address==>100.001.200.099
Proxy Port==> 8080
Again save all the settings and click BACK button and choose "Activate Profile"
Come back to SERVICES==>WAP==>Homepage
and you r ready to use Airtel Live...
Jul 19, 2009 | i-mate JASJAR Smartphone
Airtel gprs settings for chinamade mobile
Here is the Mobile Office, Airtel Live and Airtel MMS settings for ALL CHINA Mobiles ==>
1) Mobile Office
existing account==>
Account Name--> MO
APN-->airtelgprs.com
Auth. Type-->Normal
Rename Profile==> Mobile Office
Homepage==>Google
data account==> MO (which we created previously)
Connection Type==>
b) Connectionless
c) HTTP
choose a) Connection-oriented==>
IP Address==>202.056.231.117
Security==> off
and you r
ready to use Mobile Office...
2) Airtel Live
APN-->airtelfun.com
Auth. Type-->Normal
Connection Type==>
b) Connectionless
c) HTTP
choose c) HTTP==>
Proxy Port==> 8080
3) Airtel MMS
Account Name--> MMS
APN-->airtelmms.com
Auth. Type-->Normal
Rename Profile==> Airtel MMS
Homepage==>http://100.1.201.171:10021/mmsc
data account==> MMS (which we created previously)
Connection Type==>
b) Connectionless
c) HTTP
choose c) HTTP==>
Proxy Address==>100.1.201.172
Proxy Port==>8799
and you r ready to use Airtel MMS...
Enjoy....
Irshad
Jul 08, 2008 | Cell Phones
Samsung Omnia  Cell Phone Logo
15 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
