Question about JVC AV-32260 32" TV
Hi i turn my tv on and it goes of the tv timer light is flashing any help
3 Suggested Answers
  • 142 Answers
SOURCE: jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Posted on Sep 30, 2008
jingjao
  • 252 Answers
SOURCE: on timer light flashing
first you need to re soldered your tv, coz 50% problem of tv is lose connection, but be careful of short circuit,if nothing happen check the horizontal output transistor,
Posted on Oct 31, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Wife turned on tv and the red "on timer" light goes from steady red (on) to blinking(timer mode I presume).I unplugged it for a few hours and it still does the same thing... starts to come on...
It seems problem in deflection section of tv and most probably vertical deflection section got problem that is why tv selected protection mode to avoid further damage and does not power up.
TV should get repair under $150 if its picture quality was good.
Thanks.
Feb 04, 2011 | JVC Televison & Video
Tv wont turn on, red timer/delay light flashes starts to come on then shuts off again
hi,
watch how many times ur standby indicator flashes. flashing of led is its self diagnosing system. if u tell me how many times its flashes, then i can tell u where is the problem
ok
Jan 03, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
JVC AV-32260 32" TV Logo
160 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
