Question about Zodiac Jandy Legacy LRZ 175K Commercial Pool Heater (Draft Hood)
Pilot stays lite but burner won't ignite
I'm opening the pool for the season. i lit the pilot of water heater it stays on. but burners won't ignite.
  • Zodiac Master
  • 1,631 Answers
There are more problems possibly occurring, than those already listed.
but I would agree, if you are not that diligent, or not really a DIY'r, call a pool Service tech!
That pilot is staying on, is a good thing, could be only a minor problem - try thoroughly cleaning your filter, and make sure all baskets are clean. If heater still not firing...
  • Could be a weak pilot generator, not providing enough Milivolts to operate the rest of the safety sensors/switches.
  • Possibly a bad gas valve - main valve not opening for burners
  • A bad pressure switch
  • The fusible link, may have burned
  • A hi limit is open = bad hi limit there are two of them
  • Might also be a bad heat control assembly - thermostat
  • Is there proper Fuel Supply? Is valve open?
A good tech will find the problem in a few minutes - might be worth the service call charge?
but... If you want to continue troubleshooting, return in this posts comment section. Hope this helped?
Posted on May 24, 2015
    Problem Solver:
  • 11 Answers
Did you turn the control from pilot to on. Second water flow through heater if low on no water flow burner won't ignite. These are the simple checks.if this does not work save yourself a lot of head ache and call your gas company.
Posted on Oct 31, 2014
    Champion:
  • 305 Answers
You have either an open safety, poor wiring connection, or problem with tstat controls
Posted on Apr 16, 2014
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Laars pool heater's burner wont stay lit
Check the burner, the holes may be plugged, especially at the beginning of the season. Same happens to the pilot light tube. Spiders love to make nests inside those small holes clogging everything up.
Aug 13, 2014 | Teledyne Laars Pool & Spa
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Zodiac Jandy Legacy LRZ 175K Commercial Pool Heater (Draft Hood) Logo
219 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
