Question about Kenmore 22422 Top Load Washer
How to fix my Kenmore 21252 top-load washer Grinding Noise In Washer
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Posted on Jul 30, 2007
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
  • 91 Answers
SOURCE: kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Posted on Jan 02, 2009
ldsaunders
  • 31 Answers
SOURCE: Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Posted on Feb 12, 2009
  • 2468 Answers
SOURCE: loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Posted on Mar 05, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore Energy Eco care system won't spin at all
Kenmore ECO Care system front load washer final spinal cycle
won't shut off. Machine shakes violently.
Feb 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore elite heavy duty top load washer
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 60 series grinds when spin starts
try taking the pump off the motor and see if the grinding noise stops could be something in your pump or a bad pump
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer elite top load
sounds like you have a bad coupler.mach does not have a belt it uses a coupling system between the motor and trans.if you fill mach and it makes the same noise in agitation,replace the coupler
Sep 21, 2008 | Kenmore 24032\24036 Top Load Washer
Grinding noise in top load kenmore washer when agitating
IT COULD BE A FOREIGN OBJECT IN THE PUMP. THE ONLY OTHER ITEM WOULD BE THE DRIVE COUPLER LOCATED BETWEEN THE MOTOR AND THE TRANSMISSION.
CHECK THE PUMP FIRST. IT IS ATTACHED TO THE FRONT OF THE MOTOR WITH TWO CLAMPS.
Apr 13, 2008 | Kenmore 22422 Top Load Washer
Grinding noise
replace your drive coupler. cheap fix. i charge around $60.00
Jan 01, 2008 | Kenmore 22422 Top Load Washer
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Kenmore 22422 Top Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
