Timeline of hurricane katrina - Computers & Internet
Hurricane names
Mitch (1998), Katrina (2005), Wilma (2005), Ike (2008), Gustav (2008), Irene (2011), Jova (2011), Matthew (2016), Hermine (2016), Otto (2016), Irma (2017)
Sep 13, 2017 | Miscellaneous
My washer is one that was used in Fema trailers during Hurricane Katrina. Water is leaking badly out of it. I need to replace the main seal, but I cannot figure out how to get the agitator off. Can you...
the agitator is a simple thing to remove although the threads rust and might need a little help there should be what looks like an finger grip at the top of it and it should turn anticlockwise to undo as i say it might need a little help.adrian,,,
Aug 11, 2010 | Whirlpool GSX97509 Top Load Washer
This hose fell off during transport and i can't figure out what it connects to except on one end. i lost my manual during hurrican katrina and need help, i am female so explain it to me so i can...
Without knowing what the one end connects to, it is hard to tell.
If the engine runs without this hose, it is probably a vent/overflow for the battery..
One end should connect to the battery and the other end should just hang bellow the mower.
- this prevents battery acid from corroding your mower.
Jul 11, 2009 | Garden
Old floppy disk for IBM wheelwriter to be copied to CD
If you have a floppy drive on your computer it may read on a word prosessing program.
DickyO
Apr 09, 2009 | IBM Wheelwriter 30 Typewriter
Generator will not generate electricity.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clean the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Need operating manual for 6250
Their should be a twist value on the bottom of the gas tank.( were the fuel hose attaches.
Sep 13, 2008 | Coleman Powermate Premium Plus 6250W...
PT-445CX65
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Aug 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Flooded in Katrina
Try hotairing (set 4 to 5, medium airblow)the main board, check also the mechanical connection or terminals ( I assumed you already did that).
Aug 31, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
